Elektroonika
VAG-COM / VCDS
[quote][i]Algselt postitas: -anc-[/i] kas keegi oskab kommenteerida sellist juttu? Autoks on A4 95 Address 01 ------------------------------------------------------- Controller: 8D0 907 557 C Component: 1,8L R4/5V MOTR HS D07 Coding: 04201 Shop #: WSC 06335 4 Faults Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 00561 - Mixture Adaptation 15-10 - Adaptation Limit (Add) Not Reached - Intermittent 00561 - Mixture Adaptation 12-10 - Adaptation Limit (Mul) Exceeded - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent Readiness: N/A mis need asjad tähendama peaks? Ei suutnud midagi ise üles kaevata... [/quote]
Elektroonika
VAG-COM / VCDS
24.4%
75.6%
