S - Audid
20vT - hooldus
20vT tavahooldus
[quote][i]Algselt postitas: kama2[/i] eeldame, et see masin: VAT Registration No.: Name: Manufacturer: Audi Address: Model: Year: 1993 Registration: Tel - Private: Mileage: Tel - Business: Job number: Lubricants and capacities Notes Specified value Measured value Engine oil grade - cold climate SAE 5W/30 Engine oil grade - moderate climate SAE 15W/40 Engine oil grade - hot climate SAE 20W/40 Engine oil classification API/ACEA SG/A2-96 Engine oil grade - alternative - moderate climate SAE 10W/40 Engine oil classification - alternative - moderate climate API/ACEA SG/A2-96 Engine with filter litres 5,0 Gearbox oil grade SAE 75W/90 Synth. 123 Gearbox 4/5 speed litres 2,2-2,7 Automatic transmission fluid Type Dexron II Automatic transmission (drain & refill) litres 2,7-3,5 Differential oil grade - front SAE Synth.75W/90 Differential front/AT litres 0,7-1,0 (AT) Differential oil grade - rear SAE 75W/90 Synth. Differential rear litres 1,7 Cooling system litres 8,0 Brake fluid Type DOT 4 Brake fluid litres 1,0-1,5 Power steering fluid Type VW G 002 000 171 Power steering fluid litres 1,0 Autodata Note 123 Gearbox oil capacity Transfer box = 0,8 litres Transfer box (01F transmission) = 1,02 litres Autodata Note 171 Power steering fluid SLS = 2,5 litres. Manufacturer: Audi Model: 100 (91-94) 2,8 Engine code: AAH Output: 128 (174) 5600 Ehk saab aru, PDF ei taha raamid eksportida :) Ainult S4'l 2.8 mootorit ei näita, on 2,2 [/quote]
S - Audid
20vT - hooldus
20vT tavahooldus
22
31.3%
68.7%
