S - Audid
20vT - hooldus
Hammasrihma vahetus 2,2T
[quote][i]Algselt postitas: Geo[/i] Norralased on leidnud mõne lahenduse selleks et natuke aidata alumisel hammasrattal kohal püsida... [b]Crank Nose Friction Shim[/b] Got problem with broken key on the lower timing belt gear? Here is the solution: [img]http://www.rosten-performance.com/images/flywheel_shims/nose_crank.jpg[/img] # For all 5cyl 10v/20v engine's # Installed between crank nose and crank pulley # Only 0.1mm thick # The surface contains a special nickel/diamond coating # The friction from this installed shim holds the pulley in place [url=http://][b]www.rosten-performance.com[/b][/url] [/quote]
S - Audid
20vT - hooldus
22
24.0%
76.0%
