Prinditav versioon | Telli teema e-mailile | Lisa lemmikutesse   Tee uus teema
 Lehekülgi:  1  2  3  4
Pealkiri: Päevatulede automaatne lülitus (Vastuseid: 94 | Vaatamisi: 76180)
melnits
Registreerunud 19.01.10
Auto: Audi A6 Quattro 3.0 (162 kw) sedaan 2002.a
postitati 30.03.12 18:45 Tsiteeri
Kui nii, siis teen selle ära. See vajalik vidin ka olemas millega mugavalt juhtmed ära ühendada.
Suured tänud kaasa mõtlemast!:)
Maku
postitati 19.08.12 03:26 Tsiteeri
http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Central_Electronics_(8EC/8ED)#Coding
[09] - Central Electronics
Coding
?xxxx: Chassis
0 = Limousine (PR-K8B)
1 = Avant (PR-K8D)
2 = Cabriolet (PR-K8K)
x?xxx: Driving Light Switch
0 = Rain/Light Sensor (G397) not installed (PR-8K0/8K1/9C6/8K4)
1 = Rain/Light Sensor (G397) installed (PR-8K3/8K7/9C7/8K9)
xx?xx: Trailer Hitch
0 = Trailer Hitch not installed (PR-1D0)
1 = Trailer Hitch installed (PR-1D2)
xxx?x: Headlights
0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7)
1 = Halogen Headlights with Daytime Running Lights (PR-8Q0/8Q1+8K1/8K3/9C6/9C7)
2 = Bi-Xenon Headlights with Daytime Running Lights (PR-8Q3/8Q5+8K9/8K4)
3 = Bi-Xenon Headlights w/o Daytime Running Lights (PR-8Q3/8Q5+8K0/8K7)
4 = Bi-Xenon Headlights with Daytime Running/Tail/License Plate Lights (PR-8Q3/8Q5+8K1/8K3)
xxxx?: Country
1 = Rest of World/Nordic Countries/Denmark/Croatia/Baltic Countries with Bi-Xenon
2 = Nordic Countries/Denmark/Croatia/Baltic Countries without Bi-Xenon
3 = USA/Canada with Bi-Xenon
4 = Canada without Bi-Xenon
5 = Special Vehicles
Adaptation
Channel 001: Coming Home Time
Activation Time of the Coming Home Lighting.
Standard: 30 Seconds
Range: 0...60
Increments: 1 Second
Channel 002: Brake Light Dimming
Standard: 30 %
Range: 13...40 %
Channel 003: Tail Light Dimming
Standard: 32 %
Range: 13...40 %
Channel 004: Rear Fog Light Dimming
Standard: 28 %
Range: 13...40 %
Channel 005: Daytime Running Lights Dimming (Low Beam)
Affective with Halogen only.
Standard: 92 %
Range: 51...100 %
Channel 006: Daytime Running Lights Dimming (High Beam)
Affective with Bi-Xenon only.
Standard: 70 %
Range: 51...100 %
Channel 007: Daytime Running Lights Dimming (Fog Lights)
Affective for Canada only.
Standard: 92 %
Range: 51...100 %
Channel 008: Daytime Running Lights
Standard: 1 (ON)
0 = Daytime Running Lights OFF
1 = Daytime Running Lights ON
Heiki76
Registreerunud 31.01.06
Auto: audi a4 b6 2,5d avant
postitati 19.08.12 09:51 Tsiteeri
Algselt postitas: tiitk
Tuledelülitisse tulevas kimbus lõikad läbi TFL klemmile mineva kollase/valge juhtme 3-4 cm pistikust eemal, autopoolse otsa isoleerid. Vaheleastujaga ühendad lülitipoolse kollase/valge otsa ja NL klemmilt tuleva rohelise/valge juhtme. Gabariidid põlevad ja lähituledega udukad põlevad vaid udutulede sisselülitamisel. Ajakulu 5 minutit.
Kui seni Xenonid automaatselt koos süütega ei lülitunud, siis lihtsalt rohelise/valge juhtme külge vaheleastujaga juhe ja ühendada see TFL klemmiga.
Vaheleastuja on http://www.autoladu.ee/main/product/cid/196/id/2089
Tekkis ka huvi asja vastu. Tegemist 99a b5-ga. Tulede lülitiks kang ja udukate lüliti keset armatuuri eraldi. Kas saab sama õpetust kasutades udukad automaatselt põlema?
EDIT: Uurisin juba järgi, kollast/valget juhet sinna pistikusse ei tule.
v6hitler
Registreerunud 17.08.12
postitati 29.08.12 10:32 Tsiteeri
Kas c5 kerega a6-el saab samuti kodeerida sedasi et 0 asendis käivitades auto süttivad udutuled? ei seisa pidevalt meeles seda nuppu keerata ja mis neist xenonitest ikka päevasel aal ajal
postitati 29.08.12 11:59 Tsiteeri
C5't arvutiga kodeerida ei saa.
Saab C6't ja osasid B6'si.
repsu007
Registreerunud 04.08.09
Auto: C7,B6q,B2q
postitati 27.09.12 19:42 Tsiteeri
Tehke nüüd mulle kh selgeks kuhu minema pean või mida tegema. 2004a A8 ja tahaks et koju mind tuledega saadaks ja kuna päevatulesi pole siis sellel ajal udukad põleks automaatselt. Seda auto nuppu pole on aind off pargid või tuled.
Raske jalaga.
renv
Registreerunud 28.02.11
Auto: b7 a4 2.0tdi
postitati 29.09.12 09:06 Tsiteeri
Autoks b7, halogeentuled, "Auto" funktsioon olemas.
Tegin tuled automaatseks, kuid huvitav kas järgnev asi on võimalik?:
0 - kõik tuled kustus
AUTO - valges päevatuled, pimedas lähituled
Hetkel siis 0 peal põlevad päevatuled.
Ilmselt peab mingeid juhtmeid lõikuma?
Coding
?xxxx: Chassis
1 = Avant (PR-K8D)
xxx?x: Headlights
xxxx?: Country
Infoks niisama ( halogeen tulede korral) :
xxx14 - põlevad päevatuledena udutuled, esimesed suunatuled ja gabariidid
xxx13 - põlevad päevatuledena lähituled, esimesed suunatuled ja gabariidid
xxx24 - põlevad päevatuledena kaugtuled( saad muuta tugevuse % ) ****
xxx12 - nii nagu eestis olema peab-automaatsed lähituled ( saad muuta tugevuse % )
**** kuid keerates lähitulede peale kaugtuled ei funktsioneeri, armatuuris kaugtule kangi liigutades sinine tuli süttib, kuid kaugtuleni vool ei jõua
Amadeus
Registreerunud 08.10.02
Auto: C7q
postitati 29.09.12 11:24 Tsiteeri
Algselt postitas: renv
Light sensor on? Vist on kui Auto funktsioon on. Milliseid tulesid sa päevatuledena kasutad - udukad, või on halogeentulel DRL olemas? DRL-ga varianti saab kenasti AUTO peal toimetama. Teoorias peaks saama ka nii, et päeval udukad ja kui pimedaks läheb, lülitab pooltuled põlema. 07' Passat B6 sai niimoodi kunagi kodeeritud.
renv
Auto: b7 a4 2.0tdi
postitati 30.09.12 08:20 Tsiteeri
Algselt postitas: Amadeus
Light sensor on jah. "Päevatuledeks" panin lähituled, millede võimsuseks adaption kaudu 51%. Pimeda saabudes lükatakse automaatselt lähituled 100 peale tagasi. Eraldi DRL ei ole. Uduka variant väga ei meeldi, pealegi see oleks vaid koos suundadega... Udutulede variant oleks vastuvõetav ainult sellisel kujul, kui gabad ega suunad ei põleks.
Ei oska keegi soovitusi anda? :
Wiltz
Registreerunud 05.02.13
postitati 06.02.13 22:28 Tsiteeri
Tegemist Audi a3-ga aastast 2010 ja pärit ta Saksast. Halogeen tuledega ning lülitil on "auto" funksjoon ning hämara andur. Ühesõnaga hetkel on nii, et auto asendis põlevad ainult ees päevatuled valgel ajal ning hämaras lülitab automaatselt ümber pooltuled+gabariidid taga. Küsimus siis kas oleks võimalik ringi kodeerida nii, et ka valgelajal põleksid gabariidid taga? Kui võimalik siis kelle poole peaks Tallinnas pöörduma antud küsimusega.
Väga vabandan kui küsimusele vastus kuskil foorumi avarustes olemas on. Olen alles uus siin foorumis ja ka see auto mu esimene Audi;)
Mõistvat suhtumist lootes.
postitati 07.02.13 08:27 Tsiteeri
Võib proovida, kuigi just täna jäi arvuti koju :(
Vajadusel võta ühendust.
iguaan
Registreerunud 10.02.13
Auto: B7 A4 Avant 2.0T quattro 147kw '05
postitati 12.03.13 15:46 Tsiteeri
Mure siis sarnane, et auto toodud saksast ning seetõttu päevasel ajal on hämaraanduri tõttu tuled üldse kustus (AUTO asend).
Kaabliga instrumentide alt riigi muutmine tulemust ei anna, kuna kui muuta codingut [09] - Central Electronics alt ja salvestada, siis ära ta ei muuda. See kus näitab vag number ja component, sinna asemele tekib mingi tundamatu tähtede jada (ei meenuta kuidagi koodi) ja kui uuesti codingu alla minna, siis number vana.
Keegi äkki teab öelda milles võib kala olla?
EDIT: tegu halogeenidega ja puuduvad DRL ning samuti MMI
KuldarA
Registreerunud 26.11.11
postitati 12.03.13 15:48 Tsiteeri
Algselt postitas: iguaan
C6-l saab selle lülituse teha MMI-st. Daytime driving lights ON/OFF vms oli seal valik.
real1
Registreerunud 09.06.06
Auto: B3, B4, B5; B7, C4, C6
postitati 12.03.13 17:58 Tsiteeri
Minul on selline probleem, et ei saa kuidagi tulede automaatsest lülitusest lahti. Süüte keeramisel lähevad põlema kõik pargid ning lähituled. Seni eelmise autodega - ühel oli vahele pandud mingi karbike, lõikasin ühe juhtme läbi, automaatne lülitus elimineeritud. Teisel autol oli pusitud juhtmetega, harutasin kõik lahti ning ühendasin nii nagu varem oli, sain korda. Sellel autol aga ei ole mingit nähtavat jälge kuskil. Pole ühtegi juhet läbi lõigatud, pole mingit karpi vahel. Võimalus siis et kas on tulede lüliti sees midagi ümber tehtud või arvuti abil. Viimast varianti ei taha ka uskuda, arvan, et selle aastaarvuga autol ei saa nii. Puudub ka Auto asend. Tegu on A4 1998. Tulede lülitiks on, nagu ikka, suunatule kandi juures väike kang.
Uurisin ka alarmi, ei leia seost. Ka alarmi kaitsmete eemaldamisel lähevad tuled endistviisi süütega põlema.
Küsimus - kas on võimalik arvutiga asja korda saada või on asi tulede lülitis või veel kuskil mujal? Pole veel lülitit lahti harutanud..
iguaan
postitati 15.03.13 17:36 Tsiteeri
Sai siis pisut loomkatseid tehtud ning avastasin, et kui tulede tüüp muuta xenoniks, siis saab vahetada ka riike. Kuid kahjuks ei saanud peale riigi muutmist tulesid tagasi halogeenidele panna (välja arvatud juhul, kui Saksamaa tagasi panin).
kaints
Registreerunud 31.07.07
Auto: 100 2,8 quattro ja 90 2,3 quattro
postitati 11.09.13 08:14 Tsiteeri
Tere
Küsimus selline, et autoks A6 2010 a. Päeval kui tulede lüliti on automatic peal, siis paneb xenonid põlema ja taga tuled ka, 0 asendis põlevad ees ja taga led tuled. Kas on võimalik nii teha et automatic asendi peal on päeval ainult led tuled ja pimeduse saabudes lükkab alles xenonid sisse? Ja veel üks küsimus, mis tuli on selle aastakäigu A6-l suure tule sees keskmise iluvõre kõrval, seal kus vanemal on A6-l on päevasõidu tuli?
Maku
postitati 20.10.13 22:03 Tsiteeri
Kus kohas C6-l see päevatulede lülitustundlikkuse reguleerimine käis? Lappasin Ross-Techi wikit aga ei leidnud.
Kusagilt on nagu kõrvu jäänud, et saab reguleerida, kui vara või hilja päevatuled sisse-välja lülitatakse.
Kulno
Registreerunud 20.10.13
postitati 23.10.13 11:42 Tsiteeri
Mul on olemas mingi AUTOCOM OBD jublakas millega saab veakoode ja asju vaadata paljudel autodel. Kas selle aparaadiga saaksin ka kuidagi Q7-l (2007a MMI-ga) kodeerida neid päevatulesid? Mul paneb ta päeval ainult halogeenid põlema, aga tagant on kõik pime. Soov oleks ka tagumised tuled koos päevakatega põlema saada. Usun, et see on võimalik, aga kui raketiteadus see sellise juhtme ja softiga on? :)
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 23.10.13 11:47 Tsiteeri
Algselt postitas: Kulno
Autocom cdp+ ?
Life is tough.
Kulno
postitati 23.10.13 14:40 Tsiteeri
Autocom cdp+ ?
ma nii täpselt ei tea, aga reedel võtan selle oma kätte ja siis saab proovida ja mängida - isa kasutab seda rekkade (volvo) häälestamisel.
postitati 23.10.13 15:24 Tsiteeri
Kui sa ei tea, mida sa teed, siis parem ära tee, eriti sellise seadmega, mis sobib kõigele. Enne kui mingeid koode üle kirjutama hakkad, jäta vanad meelde.
Sul on vaja tuled ümber kodeerida põhjamaade regiooni.
OOOO, VW, Seat, Skoda DIAGNOSTIKA, OSTUABI (võimalik üle Eesti), kodeerimine, (de)aktiveerimine, aut. kastide adaptsioonid jne. (Uusim litsentsiga orig. Ross-Tech PRO V2 seade + uusim tarkvara VCDS 23.3.1 + pikk kogemus). 2g, HN+, MHI2, MHI2Q uuendused, NAVI 2023, VIM, SpeedCam, Carplay, Android Auto aktiv. jne. Läbitud kilomeetreid ei muuda. U2U või 55547002.
postitati 23.10.13 15:28 Tsiteeri
Algselt postitas: Maku
Pead valgussensorit veits häälestama. Vaata A8 D3 alt, seal oli vist midagi selle kohta. Päris nii Adapt--Channel jne. se ei käi, nagu näiteks A4-l. Mul omalgi süttivad xenonid näit. pilves ilmaga, mis mulle ei meeldi. Homme vaatan seda oma C6-e peal.
Maku
postitati 23.10.13 17:23 Tsiteeri
Ma suutsin oma kaabli ka lukku ajada, ei saa ise katsetada. Anna siis teada, kui leidsid miskit. :)
Kulno
postitati 23.10.13 18:11 Tsiteeri
Ma enne midagi muutma ei hakka kui pole asjast sotti saanud. See pole mänguauto ka mille peal katsetada :)
Kui kuhugi maale jõuan, siis kindlasti küsin abi.
iguaan
postitati 23.10.13 19:27 Tsiteeri
OT:
Automaatlülitusel ei ole meeldivuse eesmärk vaid pigem liiklusohutus.
 Lehekülgi:  1  2  3  4
[PHP: 76.0% - SQL: 24.0%]
