 Lehekülgi:  1  2  3  4
Pealkiri: Audi A6 C6 Avant 3,0TDI Q - 2007 - paukpadrun (Vastuseid: 79 | Vaatamisi: 17999)
Helina
Registreerunud 19.10.08
postitati 14.12.14 14:15 Tsiteeri
Mõtlesin, et võiks teisest Audist ka teema teha, nii hooldusülevaateks jms. :)
Soetatud sai ta 25.mail 2014. Autot ostes oli kindel tingimus, manuaal, q ja diisel. Ega tookord neid manuaale nii väga valida ei olnudki. Tulnud ta Eestisse Saksamaalt ja siin esimene omanik.
Natukene tehnilisi andmeid ka:
Vla: 2007
Kere: Avant
Mootor: 3,0TDI 171KW + chip (prj). Chip tuli alles septemberi lõpus.
Vedu: Quattro
Värvus: Tumesinine metallik
Sound: Bose
Lisavarustus:
E0A = No special edition
1KD = Disc brakes, rear
3FA = Without roof insert (standard roof)
F0A = No special purpose vehicle, standard equipment
T41 = 6-cylinder diesel engine 3.0 L unit 059.D
2ZQ = Leather trimmed multi-function steering wheel for air bag system
7Q2 = Navigation system with color screen
3L3 = Manual height adjustment for front seats
1SA = Without additional front underbody guard
7GG = Emission standard EU4 DPF
J0Z = Battery 520 A (110 Ah)
3NZ = Rear seat bench unsplit, backrest split folding
C5V = Alloy wheels 7.5J x 16
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
1LG = Disc brakes, front
8GV = Alternator 180 A
8ED = Bi-functional headlight with gas discharge lamp, for driving on the right
8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
7K0 = Without tire pressure warning light
4KR = Laminated glass side windows, rear windows in heat-insulating glass
6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated
5TD = Decorative aluminum inserts
0G1 = Gearshift lever
Q2A = Standard front seats
9Q4 = Multi-function display/on-board computerwith check control
4X4 = Side air bag, front and rear with curtain air bag
3Y0 = Without roll-up sun screen
Q1D = Sports front seats
5SL = Left exterior mirror: aspherical
7X4 = Park distance control, front and rear
0YL = Weight range 11 installation control only, no requirement forecast
X0A = National sales program Germany
8Z5 = Not hot country
2K1 = Reinforced bumpers
4K4 = Radio remote controlled central locking
6TS = Right exterior mirror: aspherical, large viewing field
1BE = Sports suspension/shock absorption
0JK = Weight category front axle weight range 10
1N3 = Speed-related variable steering assist (Servotronic)
D1D = 6-cyl. turbo dies. eng. 3.0 L/171 kW 24VV6 TDI, common rail base engine is T41
5D7 = Carrier frequency 868 MHz without panic button
4GK = Laminated windshield, with sunshield
Tehnilise poolepealt on saanud natuke kõpitsetud teist, et ikka enda jaoks oleks korras ja midagi sõitu ei segaks. Samuti kere on kettaga üle käidud ja häid vahasi peale pandud, nii suvisel hooajal kui ka nüüd talveks kaitse peal.
Tulevikus kunagi tahaks esiosa värvi saada, kuna Saksamaa kiirteed on oma töö teinud ja kivitäkse omajagu maha jätnud.
Paneks kirja siis hetkeseisuga tehtud tööd ja tegemised autole:
Läbisõit ostes 295150 KM 24.05.2014
Kohepeale ostu sai ostetud uued rehvid M+S GoodYear Ultragrip ice+ ( Kuna all olevad veljed 16` jäävad talveks ja sellel hetkel ei olnud suvevelgi veel välja valitud, sai ostetud kohe talvekad sinna peale).
Läbisõit 296500 KM
Mootori õli 2x5L Castrol 5w-30
Õlifilter
Kütusefilter
Õhufilter VAG
Salongifilter VAG
Eelsüüteküünlad VAG NGK 6Tk.
Lisa Stopptuli originaal
Tagurpidi käigu pirnid
Uued tellitud salongimatid
Auto Läigestamine (MobileSpa) - Swisswax Concorso :
http://static2.fotoalbum.ee/fotoalbum/431/256/01078781238612f.jpg
http://static2.fotoalbum.ee/fotoalbum/431/256/010787812519ca9.jpg
http://static2.fotoalbum.ee/fotoalbum/431/256/010787812705d64.jpg
http://static2.fotoalbum.ee/fotoalbum/431/256/0107878153cefb3.jpg
Nühkisin otsad ka läikima. :)
http://static2.fotoalbum.ee/fotoalbum/431/256/010787815189b24.jpg
Mõni pilt niisama ka:
http://static2.fotoalbum.ee/fotoalbum/431/256/0107878133b4928.jpg
http://static2.fotoalbum.ee/fotoalbum/431/256/01078781359fd97.jpg
http://static2.fotoalbum.ee/fotoalbum/431/256/01078781392b933.jpg
http://static2.fotoalbum.ee/fotoalbum/431/256/0107878145b508b.jpg
http://static2.fotoalbum.ee/fotoalbum/431/256/0107878147ebb43.jpg
11.08.2014
Klaaside toonimine (A-autokile):
Ilma:
http://static2.fotoalbum.ee/fotoalbum/431/256/0107878137cd862.jpg
Tooniga:
http://static2.fotoalbum.ee/fotoalbum/431/256/01078781432890a.jpg
Vahepeal kui A4 oli rajalt maas viperluse tõttu, siis sai A6-ga käidud ka AC Dragil. :) Väike teaser by Tarmo Tomson:
http://static2.fotoalbum.ee/fotoalbum/431/256/0107878129cb4ab.jpg
Läbisõit 297000 KM
Tagumised Numbritulevalgustid LED
Läbisõit 301500 KM 27.09.2014
Auto jõujaamas ja tehti järgmised asjad:
Sumpa klambri vahetus
Dpf eemaldus
egr pimedaks
chip tuning
õli vahetus Motul8110 X Clean+ 5w30
Läbisõit 302500 KM 01.11.2014
Küttefiltri vahtus taaskord kuna tulid need esimesed külmad ja paaki oli omajagu suvist diislit jäänud, siis tekkisid selle suvise kütusega väiksed käimaminemise probleemid ning nagu ikka kui talvine sisse, siis ka filter uus.
stabikas x2 lemförder
üldine kontroll autole
Läbisõit 303500 KM 27.11.2014
Esiklaasi vahetus.
Kojamehed bosch.
Lähitulevikus tulevad uued 18" suveveljed + rehvid. Läheneb ka rihmade-rullide vahetus, piduriketaste vahetus jne, eks sellest siis kui vahetamiseks läheb.
Hetkel auto töös, aga sellest siis lähemalt, kui kätte saab. :)
Muidu talla, talla ja natuke kalla. :cool:
JanisL
Registreerunud 27.11.11
Auto: A6 C5 1.8 TQ 2003
postitati 14.12.14 14:22 Tsiteeri
Mis siin muud ikka kui ilus auto ja edu:)
nimi
Registreerunud 15.01.09
Auto: B5 1.8tq STW, B5 S4
postitati 14.12.14 18:54 Tsiteeri
Kui palju peale chipi kw peaks olema?
Mis 400m aeg?
Helina
postitati 14.12.14 18:58 Tsiteeri
Algselt postitas: nimi
Mis 400m aeg?
Ma BR klassis sõitsin, seal ei hakanud väänama midagi, ei mäletagi mis see parim aeg tuli. ( Dragi ajal chipi peal ei olnud veel! ). Chipi kohta võibolla teab prj täpsemalt öelda, palju sinna ca juurde läks. Dünos muidugi käinud ei ole.
postitati 14.12.14 19:31 Tsiteeri
No lõpuks siis tuli ikka jutt ära. Väga tubli.
Hoiab teemal pilgu peal uuenduste osas ;).
anduke88
Registreerunud 17.04.07
postitati 15.12.14 09:40 Tsiteeri
Väga kena masin. :cool: Edu ja mõnusaid kilomeetreid.
Väljast sarnane enda omaga :D
Üks küsimus ka: kuidas ja millega need summuti otsad selliselt läikima said?
Oma masinal samamoodi kiirteedel veidi "kõrbema" läinud välimusega torud...ja see rikub tagaosa ilmet.
Helina
postitati 15.12.14 12:30 Tsiteeri
Black diamond metal polish pastaga. :) http://carolim.ee/et/home/7344-black-diamond-metal-polish.html
postitati 16.12.14 00:43 Tsiteeri
C6 ka nüüd peres. Kuidas siis mugavus ja kuidas see B5lt C6ele üle mineku vahe ka tunda? Ikkagi ülejärgmise põlve (suur-?)keskklass kolimine.
:cool:
Helina
postitati 16.12.14 05:34 Tsiteeri
Sõidan mõlema autoga paralleelselt, aga eks c6 muidugi igas mõttes mugavam. Samas kui B5 roolis, siis seal on samuti feeling omaette, kaks täiesti erinevat autot.
Aga eks 7 kuuga juba harjunud ka selle mugavusega. :)
B5-es tunnen puudust mmi nupust ja käsi automaatselt otsib seda. :D
Tõnts
Registreerunud 19.06.06
postitati 16.12.14 08:18 Tsiteeri
Väga ilus auto ja manuaal on kindlasti hea valik! Ootan põnevusega, kuidas see auto aasta pärast välja näeb. :cool:
paukpadrun
Registreerunud 20.04.07
Auto: A4 b6, Cabrio
postitati 16.12.14 18:11 Tsiteeri
Algselt postitas: Tõnts
Tõenaäoliselt ta väga ei muutu:). Ainult suveveljed 18tolli ja võimalik, et tagastange lisa muutub selliseks, et oleks võimalik mõlemale poole tuua välja 2 summuti otsa.
Kaits
Registreerunud 01.03.03
Auto: RS 6 Avant
postitati 17.12.14 16:08 Tsiteeri
Algselt postitas: paukpadrun
...võimalik, et tagastange lisa muutub selliseks, et oleks võimalik mõlemale poole tuua välja 2 summuti otsa.
Mida rohkem korstnaid, seda kulukamaks korstnapühkimise teenus omanikule läheb ;)
Tarmo_j
Registreerunud 12.05.13
Auto: Audi A6 C6 3,0tdi 2004a
postitati 17.12.14 17:56 Tsiteeri
Nähtud ka oma silmaga. Korralik ja aus liikur.
Ise oleks ette ka mingi 50% tooni pannud, muidu kole akvaarium :D
Helina
postitati 17.12.14 18:33 Tsiteeri
Algselt postitas: Tarmo_j
Ise oleks ette ka mingi 50% tooni pannud.. :D
Nu see on selline asi, mida saab alati vajadusel panna, lihtsalt ei viitsi pärast seda maha kiskuda, kui mingi vigin peaks kusagilt selle kohta tulema. :P
Leht
Registreerunud 18.12.05
Auto: S4
postitati 17.12.14 21:46 Tsiteeri
Väga kena aparaat,nähtud,katsutud.Ja sellisel autol peaks suvine velg ikka hakkama 20 tolli alates :P Madaldus muidugi jne :P
Helina
postitati 18.12.14 06:34 Tsiteeri
No nahkade peal just mugav sõita pole. :) 20 tollise uue rehvi hind on ka päris krõbe. Aga madalduse peale ka mõeldud juba.
Tarmo_j
postitati 18.12.14 14:38 Tsiteeri
50% toon küll kellegile ette pole veel jäänud.
ÜV on teema, aga siis äkki kannatab klaase vahetada.
postitati 18.12.14 16:36 Tsiteeri
Selle 50%-ga sõitsin kevadest saati, aga nüüd ÜV tarbeks sai klaasid ära vahetatud ja hoopis paremini on näha pimedas praeguste vihmaste ja sombuste ilmadega, seega ilmselt kevadeni sõidab ilma toonita. Iseasi on muidugi klaaside vahetus C6-l.
Fugitive
Registreerunud 12.02.06
postitati 18.12.14 16:47 Tsiteeri
C6'l pole see kõige meeldivam protseduur. Enda C5'l oli kõige õrnem toonkile esiustel, pole 4,5a jooksul ei politseid ega ülevaatuse onu häirinud, ja sõida saab ilusti nii vihmaga kui ka pimedas. Üleüldiselt see, kui hea on nähtavus toonklaasiga, vaadates auto seestpoolt väljapoole, sõltub kilest - kallima ja kvaliteetse kilega näb väga hästi.
Harry_R
Registreerunud 07.12.05
postitati 18.12.14 20:53 Tsiteeri
Mul Audil oli ees 35%, praegusel samamoodi ja siiani pole probleeme olnud. Eks ülevaatus on teine asi, seal pole veel käinud. Sügis ilmadega, kui on pime ja tume kõik, siis on olnud hetki, kui lasen aknad alla igaksjuhuks, et ilusti näha, aga kui lumi maas, pole muret ja suvest pole mõtet rääkida, siis on ikka väga hea, kui päike näo külge ei kõrveta. Ja korra aasta-kahe tagant võib selle ohvri tuua, et ÜV jaoks maha kiskuda.
Mina ilma ei oskaks enam ja kui aus olla, siis võiks nõksa tumedamgi olla. :P
postitati 18.12.14 21:00 Tsiteeri
Enne ülevaatuse putkasse sõitmist lased esiklaasid alla:P.
Fugitive
postitati 18.12.14 21:04 Tsiteeri
Ega seal punktis pole lollidega tegemist :P
Harry_R
postitati 18.12.14 21:15 Tsiteeri
Aknad alla lased tekitad pigem just kahtlust ja need libistatakse kohe huvi pärast üles tagasi. :) See esimeste küljeklaaside toonimine vähe tumedama kilega peab olema teadlik risk, millega tuleb arvestada. Politsei ei pane tähele, kui just päris prügikott pole, aga ÜV meestega see läbi ei lähe (seaduslikult). Mul on õnneks aega veel selleni.
Helina
postitati 19.12.14 18:44 Tsiteeri
Täna sai masina remondist kätte, vahetusse läks hooratas ( originaal ), ja sidurikomplekt ( Sachs ). Vana hooratas oli täielikult kinni jäänud ja sidurgi viimasel piiril. Nüüd nendega siis ok. :)
Elu näinud asjad:
http://static2.fotoalbum.ee/fotoalbum/431/303/0107901849d4f15.jpg
http://static2.fotoalbum.ee/fotoalbum/431/303/01079018514d67e.jpg
Rääkides sellest esimeste küljeklaaside toonimisest, siis ega puudust ei tunne just ja eraldi klaasi kindlasti sellejaoks soetama ei hakka, et siis neid edasi-tagasi ümber vahetada. :)
ReimsR
Registreerunud 17.06.12
Auto: A6 C7 3.0BiTDI Quattro, Opel Manta
postitati 19.12.14 21:07 Tsiteeri
Suht jabur muidugi lapata neid klaase,endalgi jäid toonimatta,kuna abikaasa lapsega sõidab samuti.Pane neid politseionuga vaidlema kuskil teepeal.
Aga mitte see ei köitnud mu huvi siia teemasse postitada,vaid pigem see,et vaadates su asukohta kus elad(Tallinn),siis miks valisid manuaal käigukasti?
Lihtsalt huvitav oleks teada,kuna ise olin ka põline kaikavend ;)
Täna ma enam ei taha linnas ise käiku vahetada...
Mina olen ka oma c6-ga väga rahul!Omanud ka juba suts üle aasta ja ka peamiselt nagu Sinulgi(vabandan sinatamise pärast)ainult kalla ja talla.
 Lehekülgi:  1  2  3  4
[PHP: 71.7% - SQL: 28.3%]
