Lehekülgi: 1 2 3 4 5 6 |
Race.Fi
Registreerunud 17.03.11
postitati 05.11.18 15:46
K&N air filters also with dimensions!
Besides model specific panel and cone air filter its possible to look and buy the filters with dimensions. Some of the filters are directly in our
stock.
K&N filters with dimensions! There is wide range of cone, panel and even triangle filters which can be found with dimensions from K&N catalog.
Usually the filter will fit many other cars as well where it is listed at the moment. From most sellest filter models like 3 and 4" cone filters we
keep always in stock as they are also very practical in use. You can look up the filters directly from K&N page or for example email to us and we
will check the availability as well.
Clever search engine in K&N website (possible to look with dimensions):
»» K&N filters with dimensions
K&N filters in our webshop:
»» K&N cone and panel filters
Have a great day!
-Riku
Race.Fi
postitati 09.11.18 11:12
Weekie: Widebands -10€
Lets put widebands in 10 € discount for the next week. Innovate, PLX and VEMS widebands can be found on our stock. Of these, there is a suitable
widebands for a basic 4 cylinder or even a bigger V8.
There are three major brands in the wideband range - PLX, VEMS, and Innovate, it (Innovate) also has excellent wideband for V-engines, which has been
a favorite for American engines when two sensors have two values on the same screen. Innovates basic model MTX-L has also gained popularity over the
last few years, even as much as it is now one of the most sold wideband - in the summer, we ordered nice amount MTX-L model in our stock.
If there is wideband in the search for a turbo engine, and it would be nice to keep up to date with the exhaust temperature smartest choise is VEMS.
In addition to wideband numbers, the display shows the exhaust temperatures as well which makes it especially efficient for turbo engines. The PLX
wideband represents a slightly modern package with a touch screen and it also has been one of the best selling wideband a long time. All widebands are
also a cheap insurance for the engine when you see it right away if something is wrong.
Widebands in webshop with discounted prices:
»» Race.fi: Widebands
-Riku
Race.Fi
postitati 12.11.18 15:11
Thermo Tec heat shields keeps the heat in right places
Thermo Tec makes high quality heat shielding products almost for any purpose. Fitment is not limited for cars, for example the heat wrap can be used
for motorcycle exhaust.
Thermo Tec has a wide range of different type of heat shields available for many use. Heat wrap is easy to install for example in exhaust manifold, it
keeps the heat in the right place and also the turbocharger works nicely. Heat shied tubes are very good for brakelines, oil tubes and for example for
lambda sensor which is near to the engine. There is also "model specific" heat shields for exhaust, starter, turbo and silencer - they are not car
or engine specific, but made for the exact use. We have a big stock of Thermo Tec products, especially 30x30cm heat sticker which can be used almost
for any heat shielding.
Thermo Tec products in webshop:
»» Race.fi: Thermo Tec heatwraps
»» Race.fi: Thermo Tec heat shielding
tubes
»» Race.fi: Thermo Tec heat shield sticker
»» Race.fi: Thermo Tec heat tape
»» Race.fi: Thermo Tec heatshields
»» Race.fi: Thermo Tec heat blankets
Have a great week!
-Riku
Race.Fi
postitati 16.11.18 12:27
Weekend offer: Davies Craig electric water pumps -15%
Now its a great chance to get electric water pumps with or without controller including -15% discount. Most common water pumps are in our stock.
With Davies Craig eletric water pump you can get more trust in the cooling system, its possible to use it with the original pump or use only the
electric pump. There is pumps available between 15-150l/min, smallest ones are with plastic body and biggest models with more durable aluminium body
which will handle lots of power if needed, for example in race car.
Its possible to buy water pumps separately or as a set which includes the controller. With controller its possible to adjust water flow and even a fan
if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like 115l, 130l
and 150l are usually in stock and of course we order more when ever needed.
Davies Craig water pumps in our webshop with discount:
»» Davies Craig eletric water pumps
Have a great weekend!
-Riku
Race.Fi
postitati 19.11.18 14:20
Slippery weathers coming, more grip with Quaife differential
Quaife differential works in every conditions, it is also suitable especially for slippery weather. It does not lock the wheels, but instead transfers
more power to the wheel that has more traction.
Quaife is one of the best modifications for a car and especially for Finnish weathers. According to the customer feedback, the most common is the
improved grip when comparing to the original diff. Quaife differentials are manufactured and designed in England where the knowledge is in high level
and where all the differentials are tested before putting them to sale. Quaife works great even with big amount of snow and with the original traction
control, also the yellow light does not flash so often when there is more grip.
We have many differential in stock and we order more every week. Most common Quaifes are for German cars, but there is also a huge range for other car
models. Besides differentials, Quaife has a gear kits for transmissions and also a whole transmissions with all parts, ask more from our sales.
More information and Quaife differentials:
»» Race.fi: Quaife differentials
Have a great day!
-Riku
Race.Fi
postitati 23.11.18 09:30
Five Black Friday offers
Instead of a one weekend offer, we will post five Black Friday offers that are valid for the whole weekend. Now it is an excellent opportunity to grab
parts of the suspension, cooling, brakes and exhaust at much lower price - many of these products are in our stock. Here they are!
Mishimoto products -10%
You can find everything for engine cooling from Mishimoto! For example there is a wide range of radiators, coolers (also in model specific kits),
fans, silicone hoses and even a wheel nuts, all with BF discount. Mishimoto radiators are much bigger than OEM so they are also a great compromise for
any car - no more cooling problems!
»» Race.fi: Mishimoto products
Magnaflow catalysts -10 %
Cleaning power without power loss! Magnaflow performance catalytic converters cleans exhaust gasses without any flowing loss like in original
catalysts. Ceramic catalyst is cheap and a good choice when replacing the old broken OEM catalyst for a lightly tuned car. Metallic catalyst is a good
choice when you need more flow and a little more impact resistance.
»» Race.fi: Magnaflow catalysts
All Eibach products -15 %
Little or little more lowering but no adjustment, with or without shocks? Eibach B12 Pro-kit / Sportline kits has a lowering usually between 30-60mm
and thats it! Suspension kit is a great update for example to replace the old shocks/springs which also gives a nice little lowering which improves
handling and comfort. For adjustable needs, we recommend the Eibach Pro-street S coilover kit which has a height adjustment. Eibach also has a wide
range of other suspension parts like sway bars, spacers and bolts/nuts, check these our from link below.
»» Race.fi: Eibach products
Black Diamond -10%
Black Diamond has a wide range of braking parts for the streets and also for race use - there is lots of options Brake discs are available in grooved, drilled or both - its your choice! Black
Diamond has a low dust level, high friction and excellent heat resistance, if needed, pads are also suitable for race use.
»» Race.fi: Black Diamond products
Turbosmart products -10 %
Turbosmart has all the turbo products you need, there is a wide range of dump valves, wastegates, bleeds and spare parts - all are in discount, even
the little pieces! Most popular Turbosmart products at the moment are Turbosmart Boost-Tee bleeds which are great for boost pressure adjustment, we
also keep these always in stock. Check the range and grab yours from the link below.
»» Race.fi: Turbosmart products
-Riku
Race.Fi
postitati 26.11.18 15:36
Universal Walbro fuel pumps for any car
We have nice amount of different fuel pump types available, there is E85 pump and the flow rate very big. For example Walbro E85 fuel pump has a
450l/min flow rate which is enough for most engines
Walbro fuel pumps are fully universal parts (we have listed these also by car model) and can be used almost for any engine which runs with petrol - we
recommend these maintly for car use. If the engine does not get enough fuel it will run with lean mixture which is not so good for the engine and can
cause many problem in bad luck. Most common like Walbro 255lph models including installation kits are always in our stock. Check the pumps from our
website with more information or email/call us.
Walbro fuel pumps in our website:
»» Race.fi: Walbro 255lph intank fuel pumps
»» Race.fi: Walbro E85 fuel pump
»» Race.fi: Walbro 400lph intank fuel pump
»» Race.fi: External walbro fuel pump
Have a great week!
-Riku
Race.Fi
postitati 30.11.18 11:19
Weekend offer: RVS treatments -15%
Lets make an "diamond offer", ALL RVS treatments -15% only for this weekend. Now its a great opportunity to buy RVS treatments with big discount for
example for a christmas present.
RVS does not require much demonstration, it is a practically a working products that reduces friction and raises compression pressures (improves gear
contact in transmission). Treatments are also high capasity, with one treatment its possible going up to 100,000km and for several years, depending on
how many kilometers will come. The weekend's offer now offers you an excellent opportunity to buy treatments as a christmas gift with much better
price. Approximately all the treatments are always available from our stock, but during the offer the shelves are quickly empty - although more
products usually comes for a next working day, so they do not have to wait a long time.
RVS treatments with discount:
»» Race.fi: RVS
Have a great day!
-Riku
Race.Fi
postitati 05.12.18 14:21
Magnaflow catalyzers fits also for diesel use
With normal petrol or E85 Magnaflow catalyzers are also suitable for diesel cars. We have many Magnaflow catalysts in stock in many sizes.
Why to get Magnaflow catalyzers?
Magnaflow catalyzer is usually much cheaper than OEM catalyst and has a great cleaning power. Emission tests are not a problem, Magnaflow will handle
them easily and is a very good choice especially for car which has a little more power than original. Ceramic model is a cheap and good for lighty
tuned car for example to replace the OEM catalyst. Metallic model is for cars which has little more power and which needs more durable catalyst
(metallic can handle a small amount of collapses as well). Magnaflow catalysts are suitable also for diesel use in addition to petrol, of course
newest diesel cars also needs the OE DPF as it can not be removed from the car (not legal) and it also ensures that the car will pass the emission
tests, but if the problem is only in the catalyst, Magnaflow will do the job We have all the most popular Magnaflow models like 2.5 and 3 inch in stock.
Magnaflow catalyzers in our webshop:
»» Race.fi: Magnaflow catalyzers
Have a great day!
-Riku
Race.Fi
postitati 07.12.18 11:58
Weekend offer: STRI gauges -15%
Now its a excellent opportunity to get gauges with big discount, STRI gauges -15% only for this weekend. 52mm and 60mm precise and fast STRI gauges
ensures just the correct number in all conditions.
STRI makes the best gauges in the market! Stri DSD series has a fast and precise servo which will guarantee a precise reading in racing conditions.
STRI DSD series is very popular in track as it runs perfectly and always shows precise numbers. STRI gauges are very quiet, almost mute - automatic
calibration on every start make sure that you can always get right numbers, also in the future. Stri gauges are available in different background and
led colours or with smoke or clear lens.
STRI stock focus turned to the 52mm DSD models with a black dial and clear lens as they are the most popular ones. Other STRI gauges we can get
quickly from Europe, usually in couple of days.
Check Stri gauges in our webshop with discounted price:
»» Race: Stri gauges
-Riku
Race.Fi
postitati 14.12.18 10:36
Weekie: Kaaz differentials -10%
Lets put Kaaz differential in -10% discount in our weekly offer. Kaaz LSD differentials are excellent for race use, but also works as a compromiser in
a street racing car.
Kaaz makes high quality differentials for many race and street cars. There is a wide range differentials for most common Japan and German car like
Nissan and Volkswagen. For example Kaaz has a differential for VW 02A and 02J transmissions. Kaaz differentials are available with three different
ramp angle setups - 1, 1.5 and 2 way. Kaaz differentials are fully serviceable and you can get all mainentance parts from us like friction discs,
springs and differential oils.
Kaaz differentials are good choice especially for drifting, rally and time-attack, thats makes Kaaz manly a race differential, but of course it can be
used also in street race car as a compromise which is not a daily driver. Delivery time in Kaaz is usually under a week, sometimes even faster. Kaaz
differentials are always supplied with the Kaaz own oils, which guarantee the best possible operation in all driving conditions as well.
Kaaz differential in our webshop with discount:
»» Race: Kaaz differentials
-Riku
Race.Fi
postitati 21.12.18 13:02
Weekie: Quaife atb
We will offer Red Line 75w90/140 NS with differential purchase for a week.
Quaife differentials with lifetime warranty. Excellent product for slippy roads, for example snow. More grip!
Works with traction control, and works in street or racing purposes.
Merry Christmas!
- Race.fi
Race.Fi
postitati 28.12.18 10:44
New Year's offer: Mishimoto products
Lets put a new offer for a New Year! All Mishimoto products are now in sale including fans, clamps and radiators. Mishimoto product range got a little
bigger after we added some model specific cooler and exhaust kits.
Mishimoto radiators
Mishimoto radiator is a model specific and high quality manufactured peace of art which is a great for replacing the original radiator. Mishimoto
radiator is a much more effective and excellent compromise for any engine - no more cooling problems (not even in traffic lights). Mishimoto has a
bigger water capacity and it keeps the coolant nice and cool in every condition, whether it's driven in street or track. If there is not a suitable
radiator in the model specific listing, we have made a dimension pdf. where its possible to check the correct one with dimensions. Most popular
products are in our own stock.
»» Race: Mishimoto radiators
Mishimoto coolers
Mishimoto cooler keeps the intake air always cool! The cooler the air is, the more air can be confined to te engine - temperature rises without volume
increases. When you change the original cooler to the Mishimoto one, air cools much better and faster. You can find a suitable intercooler with
dimensions and we have also listed some model specific kits as well. Most common cooler are in our stock.
»» Race: Mishimoto coolers
Mishimoto fans
Mishimoto fans ensures just the correct air flow for any setups. There is many different sizes available, for example 8, 10, 12 and 16" ones.
Electric fan is also excellent with the original mechanic fan, for example in traffic jam or some racing conditions. For a bigger cooling needs, we
recommend the Race Line series which has enough power to keep even the biggest engine cool. Most popular fan models are in our stock and we order more
always when needed.
»» Race: Mishimoto fans
Mishimoto exhaust
Mishimoto has some exhaust available also, especially for newer cars. Kits are model specific and are available for example for Ford and Subaru.
Exhaust kit includes the model specific downpipe, flanges, clamps and its possible to choose it with or without a catalyst. Exhaust kits are in Europe
stock and delivery time is usually only under a week, so these can be delivered very fast.
»» Race: Mishimoto exhaust
Mishimoto hardware
In addition to the previous ones Mishimoto makes a high quality silicone hoses, catch cans, thermostats and clamps. Big part of installation parts and
other hardware can be found directly from our warehouse like silicone hoses and clamps in most sizes.
»» Race: Mishimoto hardware
Happy New Year!
-Race.fi
Race.Fi
postitati 04.01.19 13:33
Weekie: Davies Craig electric water pumps
Let's put the Davies Craig electric water pumps in -10% discount for the starting year in our weekly offer. Most popular and common water pump models
are always in stock.
With Davies Craig electric water pump you can get more trust in the cooling system, its possible to use it with the original water pump as a booster
or use only the electric pump - its your choice! There is pumps available between 15-150l/min, smallest ones are with nylon body and biggest models
with more durable aluminium body, which is actually a really great thing in bigger flowing rates.
Its possible to buy only water pumps separately or as a set which includes the controller. With controller its you can adjust the water flow and even
a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like
115l, 130l and 150l are usually in stock and we order more every time our stock starting to look empty.
»» Davies Craig electric water pumps
-Riku
Race.Fi
postitati 11.01.19 10:36
Weekie: Magnaflow catalysts
The super popular Magnaflow race catalyst are now in nice discount on our weekly offer. Most of the Magnaflow catalysts can be found directly from our
stock.
Magnaflow free flowing catalysts are for all serious exhaust upgrades, when you need a small but very high quality catalyst what will pass the
inspection easily and is small enough to be installed almost any car, its smaller that 0.5l bottle. Recently we got a feedback from our customer:
With an original catalysts the emissions were: CO% 3,86/3,40 HC ppm 470/250
With the Magnaflow, numbers dropped to: CO% 0,00/0,01 HC ppm 19/24.
We also have everything you need for the installation, for example exhaust flanges, V-band clamps, U-bolt clamps, exhaust gaskets and wide range of
different heatshields like Thermo Tec products.
Catalyzers (with discount) and other exhaust parts in our webshop:
»» Magnaflow catalyst
»» Exhaust flanges
»» Exhaust gaskets
»» V-Band clamps
»» U-bolt clamps
»» Thermo Tec heatshields
Have a nice weekend!
-Riku
Race.Fi
postitati 18.01.19 10:58
Weekend offer: Eibach spacers
Lets put the famous Eibach spring manufacturers spacers on discount in our weekend offer! Widening the track makes the car more stable and give much
better look. Some of the spacers are in our stock.
Its possible to look spacers by car model or with wheel specs, so basically if you know what car you are driving, then its easy to find the spacers as
well. If the car is not known or it is not on the list for some reason, they can also be searched by bolt pattern, width or center bore and of course
its possible to ask our sales for example by email. Spacers are priced as a pair and most of the thickest spacers comes with new bolts/nuts (depends
which ones car uses). Of course it makes sense to buy new bolts/nuts for all new spacers, but for some models they are listed separately. You will
find all bolts, nuts and studs from our webshop.
Aluminium spacers are also much lighter than steel spacers, but they has the same durability anyway. Some of the spacer models are in our or in our
suppliers stock and we always try to keep the delivery times fast as possible.
Eibach spacers in our webshop with discount:
»» Eibach spacers
Eibach bolts, studs and nuts for spacers from here:
»» Eibach studs
»» Eibach bolts
»» Eibach nuts
-Riku
Race.Fi
postitati 25.01.19 13:58
The webshop just got a major update, where all product images are now marked as specific or general images for each product.
Late 2018, you guys had a chance to answer a quick survey, where we asked how we could improve our webshop. After all, there's no point in just
thinking about these things by our selves.
There were many new ideas (thanks guys!), and one of them rose above the others: model specific images. Or to be precise, information on whether the
image is specific, or general. Well, we got on with it =)
We have some 14559 images in the database, which is quite a lot of imagery to tag. Of course some of the work was doable by some database mass
querying, but nonetheless, there still were quite a few images for Ari to tag or leave untagged by hand. The server also needed some work, starting
from the checkbox which is used to tell it whether a certain image is specific for a product.
This week we got things done, and the update is ready and live in the shop.
Specific images are very useful for product like these, which were just added yesterday by the way:
»» FSE fuel rail adapters
These are a direct fit on the stock fuel rail, allowing you to install any aftermarket fuel pressure regulator in line with it. Needless to say, a
specific image of the adapter is a very welcome addition.
We do have products which benefit less of the update. Consider spark plugs, where the only difference is the heat rating
»» NGK iridium spark plugs
So, this is it for this week guys and girls! Please do send us ideas and feedback in the future as well!
Race.Fi / Willem
Race.Fi
postitati 01.02.19 12:33
Weekend offer: Widebands -10€
Lets put VEMS and PLX widebands in our this weekend offer. Both are cheap insurances to the engine and for example you can get VEMS with EGT, which
will show up to the same screen with the AFR.
Today in offer: PLX and VEMS! VEMS + EGT is a excellent wideband for many cars, which has been especially favorite for turbo engines when you will see
the exhaust temp from the same screen. We recommend VEMS to any highly tuned turbo car.
The PLX wideband represents a slightly modern package with a touch screen and it also has been one of the best selling wideband a long time. Both of
these widebands are also a cheap insurance for the engine when you see it right away if something is wrong - not after something breakes down.
»» Race.fi: PLX widebands
»» Race.fi: VEMS widebands
-Riku
Race.Fi
postitati 08.02.19 13:23
Product descriptions updated and improved on several products
This week, we've updated a lot of product descriptions, especially for all the most selling products. These have been updated especially because we
want that the information is clear and important information can be found easily.
As said, this week's job has been to refresh the product descriptions of the most popular products and at the same time the description "look" is
more clear than before. As a further upgrade, the small image on the product description can now be clicked bigger into a new tab if desired.
For example, description on the Eibach lowering springs (Pro-kit and Sportline) have been updated with remarks and other important information that we
have been asked about during the time. Feedback what we have got from out customers, also shows in our description updates with more information and
details.
Updated product information can be found for example from these products:
»» Race.fi: Eibach Pro-kit lowering springs
»» Race.fi: Eibach Sportline lowering springs
-Riku
Race.Fi
postitati 15.02.19 10:38
Weekend offer: Holset HX35 turbochargers
Lets put high quality and popular Holset HX35 turbochargers in sale. More specifically we put the HX35 12cm2 and HX35 Super 8cm2 (oil/water cooled)
models in discount.
We just put a discount on Holset HX35 turbochargers and more specifically HX35 12cm2 and HX35 Super 8cm2 models. The Holset HX35 Super 8cm2 "wakes
up" comfortably from lower rounds and can be always twisted to the end. The 8cm2 housing fits nicely to 1.6 - 2.0l engines and for larger assemblies
we recommend the HX35 12cm2, which is suitable even a little bit larger engine.
Holset superchargers are available in both: Water and oil cooled models (HX35 Super), both have their own advantages: Oil may be a bit easier to
install, but water usually provides a slightly more efficient cooling. Holset turbochargers are always shipped with a model specific gasket kit, which
means you don't need to buy them separately, unless the purpose is to grab a few pieces for the future. For more information and assistance in
selecting turbochargers, please contact us by e-mail or phone. Most popular turbochargers can be found directly from our stock.
Turbochargers with discount in our webshop:
»» Race.fi: Holset HX35 8cm2 super
»» Race.fi: Holset HX35 12cm2
-Riku
Race.Fi
postitati 22.02.19 14:20
Japan Racing 2019 models now in webshop
In this week we added lots of Japan Racing wheels in our webshop with new models including. Now there is over double amount of Japan Racing wheels
than before.
We added lots of Japan Racing wheels in our webshop in this week and now we have double amount of these wheels than before, there is also lots of new
wheel models available. From Japan Racing wheel range you will find just the correct wheels for any setup, whether its a show or a offroad car - we
got it!
In addition to Japan Racing wheels we have wide range of different type bolts and nuts, which of course fit with all the Japan Racing wheels. JR
wheels usually arrive in one week from order and bolt/nuts are our normal stock, so usually you will find them directly from our shelves.
Wheels includes also model specific hub centric rings and center cups.
Order Japan Racing wheels from here with comprehensive payment methods
»» Race.fi: Japan Racing wheels
-Riku
Race.Fi
postitati 01.03.19 09:31
Rota wheels now in our webshop!
This week, Rota wheels was added in our webshop with product descriptions and model specific pictures. Rota is one of the leading brands in the market
and you can find just the right wheels almost for any car.
Rotas wheel range covers a wide range of rims, basic 5-spoke models or more rigid models designed especially for off-road use. Rota alloy wheels are
available in different bolt patterns, colors, offsets and widths. Spigot rings, center caps and nuts/bolts are always included in the shipment for
free.
Yesterday, the wheels selector was released which make searching the wheels much easier, especially if you have bolt pattern, offset and/or width in
mind. With wheel selector its possible to check only with wheel brand, but because of the large amount of wheels in the webshop, filtering for example
with bolt pattern can be quite smart. The wheel selector is now in beta stage, but will be announced officially in no time - we recommend testing!
All Rota alloy wheels from here:
»» Race.fi: Rota alloy wheels
-Riku
Race.Fi
postitati 08.03.19 14:12
Wheel selector is now officially out!
The wheel selector is now officially available from our webshop, which makes it easy to find the correct wheels. Just select the desired diameter,
pcd, width and/or offset and it will show all the wheels available with chosen specs.
Wheels selector makes it easy to find the correct wheels as almost 150 wheel articles searched by hand is pretty laborious, especially when you know
the specs. Of course its possible to check the wheels like before from articles or brands (its also possible with the wheel selector) - its your
choice!
A lot of wheels and accesories (bolts/nuts) have recently been added to the webshop, for example we added all the Rota wheels and Japan Racing wheel
amount doubled to the previous one. Spigot rings for the center bore always comes with both wheel brands and with Rota wheels, nuts or bolts are also
delivered in the package. After a week of testing, the wheel selector is officially announced, now its time to get some wheels
Wheel selector can be found from here:
»» Race.fi: Wheel selector
-Riku
Race.Fi
postitati 11.03.19 12:42
Davies Craig electric water pumps in stock
We just got a nice batch of Davies Craig electric water pumps more in stock. We took more especially 150l/min and 115l/min models.
With Davies Craig electric water pump you can get more power and trust in the cooling system, its possible to use it with the original water pump as a
booster or use only the electric pump, either way is fine! There is pumps available between 15-150l/min, smallest ones are with nylon body and biggest
models with more durable aluminium body, which is actually a really great thing in bigger flowing rates.
Its possible to buy only the water pump it self or as a set which includes the controller. With controller its you can adjust the water flow and even
115l, 130l and 150l are usually in stock and as said, we got a new batch of these in this morning.
Davies Craig water pumps in our webshop:
Have a great day!
-Riku
Race.Fi
postitati 12.03.19 15:23
Suspension to good shape with a coilover kit
With D2, Eibach and H&R adjustable suspension kit you will get the suspension in shape. We can deliver all the kits fast and most popular models
we keep usually in our own stock.
All the three brands has a suitable suspension kit for most common and not so common cars, for example D2 coilover kits has a stiffness adjustment
with height adjustment which makes it easy to make the kit perfect for any conditions. Eibach Pro-street S kits are excellent choices especially for
street use when you need a height adjustable kit which is also very comfortable.
H&R Twintube and Monotube suspension kits has almost same adjust specs, but Monotube has a different shock absorber type (upside-down) which makes
it great also for race use. H&R Twintube is great mainly for street use and Monotube for race use (it also works great in a street car as a
compromise).
Adjustable suspension kits in our webshop:
»» Race.fi: D2 coilover kits
»» Race.fi: Eibach coilover kits
»» Race.fi: H&R twintube coilover kits
»» Race.fi: H&R monotube coilover kits
Have a great day!
-Riku
