Lehekülgi: 1 .. 3 4 5 6 |
Race.Fi
Registreerunud 17.03.11
postitati 14.03.19 15:10
Eibach spacers for coming springs
Eibach spacers makes the car look and feel much better with reasonable price. Widening the track makes the car more stable and it also gives much
smoother look. Some of the most popular spacers and bolts/nuts are in our own stock.
Its possible to look spacers by car model or with wheel specs, so basically if you know what car you are driving, then its easy to find the spacers as
well. If the car is not known or it is not on the list for some reason, they can also be searched by bolt pattern, width or center bore and of course
its possible to ask from us - thats why we are here. Spacers are priced as a pair and most of the thickest spacers comes with new bolts/nuts (depends
which ones car uses). Of course it makes sense to buy new bolts/nuts for all new spacers, they are listed separately in our webshop.
Aluminium spacers are also much lighter than steel spacers, but they has the same durability anyway. Some of the spacer models are in our or in our
suppliers stock and we always try to keep the delivery times fast as possible - for example we offer express shipping from Eibach, which is usually
only a few working days (in finland) to you door / nearest pickup point.
Eibach spacers in our webshopt:
»» Eibach spacers
Eibach bolts, studs and nuts for spacers from here:
»» Eibach studs
»» Eibach bolts
»» Eibach nuts
»» Japan Racing wheel bolts and nuts
Have a great day!
-Riku
Race.Fi
postitati 15.03.19 10:13
Ultralite and XXR wheels in webshop
We have listed all the most popular wheels which are also available in our webshop from both brands. Wheels travels very quickly from the factory and
a set of spigot rings are also included for mounting.
The range of Ultralite and XXR covers lots of different type of wheels, for example a 6 and 10-spoke models. There are several color options as well
as different bolt patterns, offsets and widths, which you can choose by yourself. Both wheels brands are also supplied with spigot rings, making the
installation much easier and safer.
The wheel selector was released last week and it is now running at full power, just choose the correct diameter, width, bolt pattern and/or offset -
thats it! Wheels selector also works with XXR and Ultralite brands, so go and find the correct ones
XXR and Ultralite in webshop:
»» Race.fi: XXR wheels
»» Race.fi: Ultralite wheels
Both wheel brands are also in wheel selector:
»» Race.fi: wheel selector
Have a great weekend!
-Riku
Race.Fi
postitati 22.03.19 11:16
Bilstein suspension kits and shock absorbers from us
From us, you will find also Bilstein B14/B16 suspension kits and B8 shock absorbers. We have listed few most popular models in our webshop and you can
ask suitable kit for your car from our sales.
In this week, we listed few Bilstein B14/B16 adjustable suspension kits and also a couple Bilstein B8 sport shock absorbers. There are only couple of
kits available in our webshop, but they are listed mainly to give approx prices and availabilites.
Bilstein B8 shock absorbers are little bit shorter that OEM shocks, so they are excellent for example with Eibach Pro-kit or Sportline lowering
springs. Bilstein B14 and B16 kits are adjustable, lowering is between 30-50mm - B16 kits has also a 10 step damping adjustment for compression and
rebound (biggest difference to B14 kit). Offer for Bilstein B14/B16 or B8 shocks can be asked from our sales, for example trough spare parts
inquiry.
Bilstein suspension kits and shock absorbers in our webshop:
»» Race.fi: Bilstein coilover kits
»» Race.fi: Bilstein shock absorbers
Spare parts inquiry can be found here:
»» Race.fi: Spare parts inquiry
-Riku
Race.Fi
postitati 05.04.19 13:09
Model specific suspension listing
Finding the correct suspension parts is now easier than ever! Just select your car's make, series and model, and the shop will show you all the
model-specific parts available for it.
The suspension search shows you all the model-specific kits in one view. Whether it's D2 coilovers, Eibach B12 Pro-Kits or
B12 sportline suspension kits, or Eibach Pro-kit and Sportine lowering springs, they're all there.
The model-specific listings make things quicker, and you see everything that's model-specific and available at a single glance.
You can also narrow down the lists with the product brand and go deeper to just springs or coilovers. The shop also has several universal parts in the
traditional product categories, like adjustable endlinks and coilover helper springs.
Check out the model-specific suspension listings here:
»» Race.fi: Model-specific suspension kit listings
-Riku
Race.Fi
postitati 12.04.19 12:17
Correct rims easily through wheel selector
Wheel selector helps a lot to find correct wheels. Just choose diameter, width, pcs and/or offset. In addition, the rims can also be filtered with
different wheel brands.
Wheels selector makes it easy to find the correct wheels as almost 150 wheel articles searched by hand is pretty laborious, especially when you know
the details. Of course its possible to check the wheels like before from articles or brands.
A lot of wheels and accessories (bolts and nuts) have recently been added to the webshop, for example we added all the Rota wheels and Japan Racing
wheel amount doubled to the previous one. Spigot rings for the center bore always comes with all our wheel brands and with Rota wheels, nuts or bolts
are also delivered in the package. Usually all the wheels are in european stock, so the delivery time has been under a week in best cases.
Click the banner or this link:
»» Race.fi: Wheel selector
-Riku
Race.Fi
postitati 26.04.19 11:50
Super offer: All Eibach products -10%
Lets put Eibach products in -10% discont for the next week. Probably one of the leading spring manufacturers, Eibach is a certain choice for lowering
springs, shocks and kits. Eibach also makes high quality wheel spacers and sway bar kits.
Eibach Pro-kit and Sportline lowering springs
Pro-kit and Sportline lowering springs offer superior quality and ride comfort. They are also an OE choice of many factory sports kits from Audi and
BMW. Pro-Kits offer drops of around 30mm, and Sportline kits 40 to 50mm.
»» Pro-kit lowering springs
»» Sportline lowering springs
Eibach Pro-kit and Sportline B12 suspension kits
The B12 kits come with Eibach springs and Bilstein B8 dampers which offer firm damping and are designed for lower springs. Most models also have an
upside-down design for increased rigidity. Most customers change cars from time to time, and this is a kit many get for their new car as well. That's
about as high as customer satisfaction can get
»» Eibach Pro-kit B12 suspension kits
»» Eibach Sportline B12 suspension kits
Eibach Pro-street S coilovers
Eibach Pro-street S coilovers offer a very sporty driveability and a stepless height adjustment, still maintaining a lot of comfort. Offering drops of
20 to 70mm, the Pro-Street S coilovers are a choice of a gentleman seeking the perfect stance.
»» Pro-Street S coilover kits
Eibach Anti-Roll-Kit sway bar kits
A sway bar kit is the overlooked way to increase stability in cornering without sacrificing any of the comfort. Stiffer roll bars keep the car level
in corners, and at the same time allow for softer and more comfy springs - or overall better track performance of course - its your choice!
»» Anti-Roll-kit roll bar kits
Eibach Pro-spacers
Eibach Pro-Spacers are an excellent pair to go with Pro-Kit or Sportline lowering springs and when the wheel looks lack "it". Spacers will bring out
the wheels by the amount of their thickness from both sides. Spacers can be found with specs (pcd, center bore) or with car model, depends does the
listing recognize your vechile.
»» Eibach Pro-spacers
-Riku
Race.Fi
postitati 03.05.19 10:10
Japan Racing wheels can be bought also as "custom"
In addition to the standard range of Japan Racing wheels, many wheel models can also be ordered with the desired bolt pattern and ET number as
"custom". In this way, models that have run out of stock, for example, may be ordered little bit faster.
JR is undoubtedly the most popular wheel brand of this spring, they have a terrific look and the quality is at least very good. Delivery is also quite
fast, the wheels that are in the factory stock rarely takes more than one week to deliver at least in near of big cities. As said, several Japan
Racing models can also be purchased as "custom", the bolt pattern and the ET number can be decided by you (ET is usually set to a certain range
where to choose from).
Wheel offset:
Wheel offset is the distance in millimeters from the hub mounting surface to the center line of the wheel. A positive / bigger offset is when the hub
mounting surface is toward the front or outwards of the wheel. Negative / smaller offset is when the hub mounting surface is toward the back or brake
side of the wheels center line. Offset can also be zero, then the hub mounting surface is even with the center line of the wheel.
Bigger = wheels sit more inwards.
Smaller = wheels come out more.
Wheels includes also model specific hub centric rings and center cups.
Order Japan Racing wheels from here with comprehensive payment methods
»» Race.fi: Japan Racing wheels
Japan Racing bolts and nuts
»» Race.fi: Japan Racing bolts and nuts
-Riku
Race.Fi
postitati 10.05.19 09:42
Weekie: Eibach spacers -10%
Lets put the Eibach wheel spacers in our weekly offer, with them you will get the perfect look and much better handling. Most popular wheel spacers
are usually in our own stock and we can get the fast from the manufactuer anyway, for example with express shipping.
its possible to ask our sales for example by email (info(at)race.fi. Spacers are priced as a pair and most of the thickest spacers comes with new
bolts/nuts (depends which ones car uses). Of course it makes sense to buy new bolts/nuts for all new spacers (even for thin models). We have listed
them separately in webshop with lenght, type and thread.
Aluminium spacers are also much lighter than steel spacers, but they has the same durability anyway or even better. Some of the spacer models are in
our or in our suppliers stock and we always try to keep the delivery times fast as possible. Price for the spacers are always for pair, so if you need
them front and rear axle, order two sets.
Eibach spacers in our webshop with discount:
»» Eibach spacers
»» Eibach bolts
»» Eibach studs
»» Eibach nuts
-Riku
Race.Fi
postitati 07.06.19 12:11
Weekie: Davies Craig electric water pumps
Lets put the Davies Craig electric water pumps on discount in our weekly offer. Now its a great opportunity to get more cooling for the hot summer,
most popular water pump models are in our own stock and we order more at least every week.
With Davies Craig electric water pump you can get more trust in the cooling system, its possible to use it with the original pump or use only the
electric pump. There is pumps available between 15-150l/min, smallest ones are with plastic body and biggest models with more durable aluminium body
which will handle lots of power if needed, for example in race car.
Its possible to buy water pumps separately or as a set which includes the controller. With controller its possible to adjust water flow and even a fan
if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like 115l, 130l
and 150l are usually in stock and of course we order more when ever needed.
Davies Craig water pumps in our webshop with discount:
»» Davies Craig eletric water pumps
Invoice options at race.fi:
Collector: up to 60 days of intrerest fee free payment time. 2.95€ invoice fee. Available online.
Jousto: 14 days payment time, 4.90€ invoice fee. Available online.
Mash: atleast 14 days payment time, no fees. Available in store.
All payment types can be changed into part payment. More info about payment types: Race.fi: Payment types
Second tuner meet 20.6.2019
Next month, precisely at 20.6.2019 is being organized this years second tuner meet and it starts at 6pm. The plans familiar - Coffee, sausages, grill
and meeting place are on Race.Fi The event is cost free and for
everyone.
Place: Race.fi
Link to the event: Tuner meet 20.6.2019
-Riku
Race.Fi
postitati 11.06.19 09:47
Why its smart to buy a D2 coilover kit
D2 coilover kit is an excellent choice for street and race, all kit has a height and 36 step damping adjustment - some of the kits has also camber
adjustable top mount. Most popular sets are in our stock and others we can get usually in two weeks.
D2 has gained lots of popularity here in Finland, especially Street kit which is many peoples choice when replacing the old OEM suspension. Height and
damping adjustment is excellent for all driving conditions in Finland. In the winter its possible to lift the suspension a little and in the spring
lower again for example during the tire change. Damping adjustment gives much more comfort when its possible to adjust the stiffness depending what
surface you drive on.
Coilover kits are road legal and we deliver our approval for the inspection, with that only the wheel alignment paper is needed (and of course the car
aswell ;D). There is two years warranty on D2 street kits and it also includes the comfort warranty which means that its possible to change the spring
+ spring rates within 60 days of purchase, charging only shipping costs.
D2 coilover spare parts:
There are lots of spare parts available for D2 coilover kits, including springs, lock rings, dust boots and tools. We keep the most popular ones
always in stock and order more regularly.
D2 coilover kits in webshop:
»» Race.fi: D2 coilover kits
D2 spare parts in webshop:
»» Race.fi: D2 spare parts
everyone.
Place: Race.fi
Have a great tuesday!
-Riku
Race.Fi
postitati 02.08.19 11:21
Coming tuner meets in 2019
In this year there have been already three tuner meets and every one of them did go really well, thanks to you! But anyhow, we still have two meets
left, be there or be a square!
We will offer coffee, sausages, grill and place Event does not cost
anything and everyone is welcome there. Here is the next tuner meet with all the details.
Fourth meet
Time: 22.8.2019 at 18.00 - 19.30
Place: Race.fi
Link to the event: Tuner meet 22.8.2019
Here is the last tuner meet in this year:
Fifth meet
Time: 19.9.2019 at 18.00 - 19.30
Place: Race.fi
Link to the event: Tuner meet 19.9.2019
Welcome aboard!
- Race.fi staff
Race.Fi
postitati 15.08.19 15:15
STRI gauges gives a precise numbers in all conditions
Stri gauges for demanding street drivers and competition use. High quality servo guarantees a precise reading in both conditions. Gauges are available
in different led and dial colors.
STRI makes one of the best gauges in the market for sure! Stri DSD series has a fast and precise servo which will guarantee a precise reading even in
harsh conditions. STRI DSD series is very popular in track as it runs perfectly and always shows precise numbers.
STRI gauges are very quiet, almost mute - automatic calibration on every start make sure that you can always get right numbers. Stri gauges are
available in different background and led colours or with smoke or clear lens. STRI stock focus turned to the 52mm club sport models with a black dial
and clear lens as they are the most popular ones. Other STRI gauges we can get fast from Europe, usually in few days.
Check Stri gauges in our webshop:
»» Race: Stri gauges
Fourth tuner meet 22.8.2019
Next month, precisely at 28.8.2019 is being organized this years fourth tuner meet and it starts at 6pm. The plans familiar - Coffee, sausages, grill
everyone.
Place: Race.fi
Have a great thursday!
-Riku
Race.Fi
postitati 16.08.19 10:02
Tuner meet next weeks thursday, 22.8.2019!
left, be there or be a square! Next tuner meet is more specifically next weeks thursday (22.8).
Fourth meet
Place: Race.fi
Fifth meet
Place: Race.fi
Welcome aboard!
- Race.fi staff
Race.Fi
postitati 04.09.19 13:35
Kaaz LSD differentials is an excellent update for all setups
Kaaz LSD is in a excellent price range as you are able to get more stability and performance for your car in racing conditions with reasonable amount
of money. We also have wide range of spare parts such as friction discs and oils.
Kaaz LSD details:
- Available in Basic and SuperQ
- Fully serviceable
- High quality product from Japan
- Is in a excellent price range
- Supplied with Kaaz oils
- Usually available with 1, 1.5 or 2 way ramps
The Basic is most suitable for streets, with less preload and easier driveability that solid model, but is a great option for example for street
racer. Solid version is made purely for racing conditions with stiffer preload and with more friction discs in it. Delivery time for Kaaz products is
usually very fast and normally it's under a week to us from the Europe stock.
Kaaz LSD differentials in our webshop:
»» Kaaz LSD differentials
Have a great day!
-Riku
Race.Fi
postitati 06.09.19 10:02
Weekend offer: RVS treatments -15%
Let's put the RVS products in -15% discount for this weekend! With RVS treatments its possible to overhaul worn out engines, transmissions,
differentials and power steerings for example during oil change.
RVS is a proven nanotechnology that allows sliding and extremely durable triboceramic surface in parts of engines and transmissions. Engines or
transmissions condition improves right away and it is also protected from future wear. The RVS treatment will last 100,000km, so the price does not
end up too bad, especially when you divide the price per kilometer.
RVS treatments can be found for all applications such as engines, transmissions, injection pumps and powersteering. Over the years, RVS has sell a lot
and beginning of this week we got more stuff in our shelfs. We keep the most sellest RVS products always in stock such as diesel and petrol engine
treatments.
RVS in our webshop with -15% discount:
»» RVS treatments
Next tuner meet 19.9.2019
anything and everyone is welcome there. Here is the next and this years last tuner meet with all the details:
Fifth meet
Place: Race.fi
-Riku
Race.Fi
postitati 13.09.19 13:16
Headlight bulbs in our webshop!
In this week we started to add headlight bulbs in our webshop and now we have some! We have added mostly H1, H4 and H7 models.
Osram and Philips bulbs, more specifically Osram Night Breaker Silver, Osram Night Breaker Laser and Philips X-Treme vision bulbs, have now arrived in
our webshop. We sell bulbs mainly by pcs (like Osram), but for example Philips X-Treme visions by pair as they are always packed like that. We also
added Osram Ultra life model, which has a lifetime that is four times longer than the standard halogen bulb.
More bulbs are coming in webshop from the beginning of next week and for example we are planning to add Xenon bulbs. We will also keep the most
popular bulbs in stock.
Bulbs in our webshop:
»» Race.fi: Bulbs
- Riku / Race.fi
Race.Fi
postitati 18.09.19 13:51
More headlight bulbs in webshop
Last week we started and this week we continued to add bulbs in our webshop. Now we have Xenon bulbs also for example with D1S socket.
We have added Osram ja Philips bulbs, for example Osram Night Breaker and Philips vision bulbs. Osrams are usually sold as pcs, but for example
Philips vision series as a pair (supplier only stock this as a pair). Osram Ultra life series is a smart choice for everyday car as it has a four
times bigger lifetime than OEM bulb.
Xenon bulbs are also now in webshop, with sockets D1S, D2S, D3S and D4S. Serie is Osram XENARC NBL and four times more light when comparing to the OEM
bulb.
»» Race.fi: Bulbs
Have a great wednesday!
- Riku / Race.fi
Race.Fi
postitati 20.09.19 09:43
Weekend offer: PLX & VEMS -10€
Lets put VEMS and PLX widebands in this weekends offer. Both are cheap insurances to the engine and for example you can get VEMS with EGT, which will
show up to the same screen with the AFR - easy, right?
Today in offer: PLX and VEMS! VEMS + EGT is a excellent wideband for many cars, which has been especially favorite for turbo engines when you will see
the exhaust temp from the same screen. We recommend VEMS to any highly tuned turbo car. We have sold VEMS since 2006 and overall, it is an excellent
product!
The PLX wideband represents a slightly modern package with a touch screen and it also has been one of the best selling wideband a long time. Both of
these widebands are also a cheap insurance for the engine when you see it right away if something is wrong - not after something breaks down.
Widebands in webshop with discounted prices:
»» Race.fi: PLX widebands
»» Race.fi: VEMS widebands
- Riku / Race.Fi
Race.Fi
postitati 27.09.19 10:31
Fall's seasonal products!
We have listed seasonal fall products in to our webshop in own category. Check them out!
Under "Fall's seasonal products" we have listed parts like differentials, beams, bulbs, engine heaters and care care products.
We will and have update the category in this week and there is now different kind of "medicine" for this fall and coming winter. Most popular
seasonal products are in our own stock and also the ones that are not, we are usually able to get them for the next working day.
Seasonal products can be found from here:
»» Race.fi: Fall's seasonal products
Jousto: 14 days payment time, 2.95€ invoice fee. Available online.
Have a nice weekend!
- Race.fi / Riku
Race.Fi
postitati 02.10.19 13:45
More traction for winter with Quaife differential
Quaife ATB is easily the best differential on the market for street and race use! It's quiet, supplied with lifetime warranty and customer feedback
has always been great.
Quaife differential is one of the greatest updates for Finnish winter and beginning of it, we usually sell lots of them. When reading the customer
feedback, Quaife is more stable and has more traction when comparing to the OE diff. Differentials are made and designed in UK, where the knowledge is
in a great "shape". Every Quaife unit is also tested before releasing them in to the market. They works great in every weather and usually the
"yellow light" does not show up that often when there is more grip available.
We have Quaife units in stock and we order more every now and then, usually couple times a week. Most popular differentials are BMW and Mercedes
models, but there is also a wide range of them for other car brands. In addition for differentials, Quaife has a high quality gear kits and
transmissions available as well, ask more from our sales!
Further information and Quaife differentials in our webshop:
»» Race.fi: Quaife differentials
- Riku / Race.Fi
Race.Fi
postitati 04.10.19 12:17
Weekend offer: Black Diamond brakes -15%
Lets put the Black Diamond stuff in discount for this weekend! Now it is a great opportunity to get brake parts with great price and maybe its time to
do a whole brake job. In addition to brake parts, Black Diamond braided clutch hoses are also in offer.
Black Diamond has a great track record both on the streets and competition on both tarmac and dirt, they can also be used to replace the OEM brakes.
Black Diamond brake discs are available in three model, grooved, drilled or with both. The Brake pads have a great grip and low dust level, they can
also handle a big amount of heat. With discs and pads we recommend a braided brake hose kit, which is a great final update. Braided hoses make braking
more accurate when the balloon-like effects are reduced from the brake pedal. Brake hoses are made from RST, so they handle the Finnish weather
conditions very nicely
We recommend to use Black Diamonds brake fluid with brake parts so the brakes will run perfectly. Discount is in Black Diamond , but we have also wide
range of outlet BD parts with up to -40% off. Most common discs, pads, hoses and brake fluids are usually in our own stock. We order more brake parts
twice a week and even the most special discs arrive in less than a week.
Check the Black Diamond brakes from our webshop, prices includes discount (up to -40% off):
»» Black Diamond brake discs
»» Black Diamond brake pads
»» Black Diamond clutch hoses
»» Black Diamond brake hoses
»» Black Diamond DOT4 brake fluid
Jousto: 14 days payment time, 2.90€ invoice fee. Available online.
-Riku
Race.Fi
postitati 11.10.19 08:45
Weekend offer: Holset turbochargers
High quality Holset turbochargers are now in offer until next Friday, get yours!. Holset turbos are available with different sizes, so they are
suitable almost for any petrol and diesel engine.
The Holset HX35 Super 8cm2 "wakes up" comfortably from lower rounds and can be always twisted to the end. The 8cm2 housing fits nicely to 1.6 - 2.0l
engines and for larger assemblies we recommend the HX40 and HX50 models, which is suitable even a little bit larger engines.
Holset superchargers are available in both: Water and oil cooled models, both have their own advantages: Oil may be a bit easier to install, but
water usually provides a slightly more efficient cooling, neither is a bad choice Holset turbochargers are always shipped with a model specific gasket kit, which means you don't need to buy them separately unless the
purpose is to grab a few pieces for the coming services. For more information and assistance in selecting turbochargers write us an e-mail or call,
also the most popular turbochargers are usually in our stock.
Turbochargers with discount in our webshop:
»» Race.fi: Holset turbochargers
-Riku
Race.Fi
postitati 18.10.19 09:28
differentials and power steerings easily.
end up too bad in proportion to the benefits obtained.
RVS treatments can be found for all applications such as engines, transmissions, differentials, injection pumps and powersteering. We keep the most
sellest RVS products always in stock such as diesel and petrol engine treatments, of course we will order more whenever needed.
»» RVS treatments
-Riku
Race.Fi
postitati 01.11.19 12:15
Weekie: All oils
We tossed all the oils (Amsoil, Castrol and Red Line) in to our weekly offer. Now it is a great choice to get wide range of lubricants with better
price.
You'll get quality oils for the engine, gearbox and differential from us! All three brands produce only the very best and therefore you dare to put
them in any car as these are not "cheap mud". For example, we recommend Red Line NS oils with Quaife torsens because in our experience they have
always worked best. We keep the most popular oils and viscosities in stock and we can get more usually for the next working day. For assistance with
selecting the correct oil, please inquire from our sales, for example by an e-mail or call during our opening hours.
Oils in our webshop:
»» Race.fi: Red Line oils
»» Race.fi: Castrol oils
»» Race.fi: Amsoil oils
- Riku / Race.Fi
Race.Fi
postitati 08.11.19 12:11
Osram LED bulbs are now in our webshop!
During this week, we have added lots of Osram LED bulbs in to our webshop and now there is plenty of them available. Check all new LED bulbs from this
topic or directly from www.race.fi.
The Osram LEDriving product family has found its way into our webshop and LED bulbs are now available for replacing headlights, indicators and
interior lights. A CANBUS wiring harness is available for bulb systems to get the burned-out bulb light out of the instrument panel (the LED consumes
so little power that the car's test system interprets that the bulb is broken).
Delivery times are not overwhelming, in practice they will be available the next working day and of course we will start stocking up on all the
popular models so they can be picked up from us even right away. We also have listed Osram LED fog light kits, which are suitable to most cars due to
its universal mounting.
- Riku / Race.Fi
