Pealkiri: A6 c6 Control Module for Access and Start Control (Vastuseid: 2 | Vaatamisi: 2540)
A6Riho
Registreerunud 24.01.22
postitati 24.01.22 12:06 Tsiteeri
Tere,
Autoks Audi A6 C6 2008a 2.0tdi 103kw. autom.
Probleem järgmine. Kesklukk töötab. Võtme paned süütelukku tuleb roolilukk maha, võtit keerates ei juhtu midagi. Täiesti null, ühtegi tulukest ei hakka põlema :) . Võtme saab kätte ka, kinni ei jää. Proovisin süütelukku vahetada, ei aidanud.
Edasi arvasin, et on Control Module for Access and Start Control module viga. VCDS-iga kustutasin vead ära aga all olevad vead tulevad tagasi.
On ideid ?
Järgnevad vead sain kätte:
Sunday,23,January,2022,17:29:08:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: License Plate: 456
Mileage: 360800km-224190mi Repair Order:
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
61 62 72 76
Mileage: 360800km-224190miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 1010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601501045125
Coding: 0000131
Shop #: WSC 02323 785 00200
VCID: 63C51A8BA255B1913C-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
2 Faults Found:
00166 - Access/Start Authorization Switch (E415)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 179
Mileage: 360803 km
Time Indication: 0
Date: 2022.01.21
Time: 15:26:51
00576 - Terminal 15
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01111001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 139
Mileage: 360802 km
Time Indication: 0
Date: 2007.05.16
Time: 12:09:14
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000511526
Coding: 0000276
Shop #: WSC 02325 785 00200
VCID: 1C376177DFABCE69BD-8048
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0002122
Shop #: WSC 02256 785 00200
VCID: 3169A0C3A8295301FE-8064
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
1 Fault Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 179
Mileage: 262136 km
Time Indication: 0
Date: 2007.05.16
Time: 12:14:00
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4F0 920 901 G
Component: KOMBIINSTR. M73 H16 0240
Revision: 00200000 Serial number: 64575EC38
Coding: 0320007
Shop #: WSC 00011 888 06946
VCID: 204F5587F3C3EA8961-8074
No fault code found.
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B083300046
Coding: F5519E7730020600
Shop #: WSC 02335 785 00200
VCID: 2D51BCB3B41137E1DA-8078
2 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 139
Mileage: 360803 km
Time Indication: 0
Date: 2022.01.21
Time: 14:27:46
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 179
Mileage: 360802 km
Time Indication: 0
Date: 2007.05.16
Time: 12:14:07
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000349883
Coding: 0001004
VCID: 5EB32B7F89379C7913-800A
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 179
Mileage: 262136 km
Time Indication: 0
Date: 2007.05.16
Time: 12:14:00
Freeze Frame:
Voltage: 11.900 V
Temperature: 77.0°C
01316 - ABS Control Module
Freeze Frame:
Fault Status: 01110100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 139
Mileage: 262136 km
Time Indication: 0
Date: 2022.01.21
Time: 14:37:00
Freeze Frame:
Voltage: 11.500 V
Temperature: 77.0°C
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 139
Mileage: 262136 km
Time Indication: 0
Date: 2022.01.21
Time: 14:37:00
Freeze Frame:
Voltage: 11.400 V
Temperature: 77.0°C
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000057312
Shop #: WSC 42500 205 89061
VCID: 24475997E7DBF6A905-8070
Subsystem 1 - Part No: 4F0 915 105 C
Component: von 5DO 0000000000
Coding: 344630393135313035432035444F30303030303030303030
3 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 360803 km
Time Indication: 0
Date: 2022.01.21
Time: 17:59:06
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2022.01.21
Time: 17:59:31
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 179
Mileage: 360802 km
Time Indication: 0
Date: 2007.05.16
Time: 12:14:08
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220808718398
Coding: 0001016
Shop #: WSC 131071 1023 2097151
VCID: 275D4E9B96ED1DB120-8072
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 179
Mileage: 360802 km
Time Indication: 0
Date: 2007.05.16
Time: 12:14:07
End-------------------------(Elapsed Time: 02:36)--------------------------
jaiks
Registreerunud 21.02.11
postitati 24.01.22 14:09 Tsiteeri
Meenus selle kirjeldusega see video: https://youtu.be/qV1qLMA_ruE
Pole sama auto aga hea vaatamine siiski.
A6Riho
postitati 31.01.22 17:42 Tsiteeri
Power Supply Relay 370 viga oli.
[PHP: 79.6% - SQL: 20.4%]
