Registreerunud 25.07.14
Auto: a5 2012
postitati 26.04.23 19:54
A5 aken
2012 a5
Sai vahetatud aknatõstuk, nüüd ei toimi enam auto üles/alla. Samuti ei liigu klaas alla ust lahti tehes ning üles kui uks kinni panna.
Ideid?
jaiks
Registreerunud 21.02.11
postitati 26.04.23 21:40
Enamus audidel peaks piisama lõpupunktide uuesti salvestamisest. Ehk siis aken alla lasta ja hoiad nuppu edasi umbes 7 sekundit ja siis lased akna
üles ja jääd samamoodi nuppu edasi hoidma. Esimese korraga ei pruugi õnnestuda, võib protsessi korrata.
margys
Auto: a5 2012
postitati 27.04.23 03:36
Arvuti andis veaks: 02111 motor for window regulator
No or incorrect basic setting/adaption
Ehk siis seda üles alla laskmist ja siis nupu all hoidmist sai tehtud kordi 10 vähemalt.
Algselt postitas: margys
02111 - Motor for Window Regulator: No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Window Automatic Run not working
Pinch Protection limited
Possible Causes
Automatic Run & Pinch Protection not adapted
Possible Solutions
Adapt Automatic Run & Pinch Protection (see Special Notes)
Special Notes
Pinch Protection Adaptation
Make sure the window in question is completely closed.
Use the driver door window buttons to operate the window(s).
Roll down the window and keep holding the button down for 2 additional seconds after the window is already fully opened.
Roll up the window and keep holding the button up for 2 additional seconds after the window is already fully closed.
Now test the window automatic.
[PHP: 49.2% - SQL: 50.8%]
