Prinditav versioon | Telli teema e-mailile | Lisa lemmikutesse   Tee uus teema
 Lehekülgi:  1  2  3  ..  5
Pealkiri: kliima lisavõimalused (Vastuseid: 114 | Vaatamisi: 129532)
trey
Registreerunud 08.09.05
Auto: Audi A4 1.8 Turbo, Quattro
postitati 08.09.05 15:15 Tsiteeri
kas keegi oskab öelda mis numbri alt võiks keskmise kytuse kulu leida?
samru
Registreerunud 01.02.04
postitati 08.09.05 15:46 Tsiteeri
ma võin küll vähe teada aga keskmist kütusekulu sealt ei leia.
kama2
Registreerunud 24.08.03
postitati 08.09.05 16:11 Tsiteeri
Kliima kaudu saab järgmist infot:
Changing Degree Temperature Display
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
Accessing On-Board Diagnostic codes
Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
Code
Displayed Value
1
System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
2
Digital value of Interior Temperature Sensor, in Headliner (G 86)
3
Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
4
Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
5
Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
6
7
Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
8
Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
9
Delta value of Temperature Regulator Flap
10
Non-corrected specified value of Temperature Regulator Flap
11
Digital value of Central Flap Motor Potentiometer (G 112)
12
Specified value of Central Flap
13
Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
14
Specified value of Footwell/Defroster Flap
15
Digital value of Air Flow Flap Motor Potentiometer (G 113)
16
Specified value of Air Flow Flap
17
Vehicle Speed (km/h)
18
Actual Air Blower voltage (Volts)
19
Specified Fresh Air Blower voltage (Volts)
20
A/C Compressor (A/C Clutch) voltage (Volts)
21
Number of low voltage occurrences, non-transient
22
Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
23
Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
24
Cyclings of the switches, absolute non-fluctuating
25
Analog/Digital value, Kick-Down Switch
26
Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
27
Coding value
28
Engine Speed (RPM)
29
A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
30
Software version
31
Display check (all segments of A/C Control Head display light up)
32
Potentiometer malfunction counter, Temperature Regulator Flap
33
Potentiometer malfunction counter, Central Flap
34
Potentiometer malfunction counter, Footwell/Defroster Flap
35
Potentiometer malfunction counter, Air Flow Map
36
Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
37
Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
38
Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
39
Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
40
Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
41
Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
42
Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
43
Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
44
Vehicle operation cycle counter
45
Calculated interior temperature (internal software, in digits)
46
Outside (ambient) temperature, filtered, for regulation (internal software)
47
Outside (ambient) temperature, unfiltered, (internal software, in deg C)
48
Outside (ambient) temperature, unfiltered, (in digits)
49
Malfunction counter for speedometer (vehicle speed) signal
50
Standing time (in minutes)
51
Engine Coolant Temperature (ECT) in deg C
52
Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the ?88.8? display. See chart below.
53
Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the ?88.8? display. See chart below.
54
Control characteristics
55
Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
56
Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
57
Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
58
Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
59
Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
60
Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
61
Software version (latest)
TiitR2
Registreerunud 21.07.04
postitati 08.09.05 16:37 Tsiteeri
...paistab, et päris palju saab..:D
margus
Registreerunud 15.12.02
postitati 08.09.05 17:01 Tsiteeri
Kliima näitab kõiki väärtusi, mis on vajalikud kliima süsteemi toimimiseks või abistamiseks. Kütusekulu ei ole oluline faktor kliima jaoks ja seega ei näita see ka midagi.
Parimatega,
Margus
trey
postitati 09.09.05 06:29 Tsiteeri
Minul on kliimas 73 erinevat toimingut, kuid eespool on toodud 61 varianti...
kust võiks need ylejäänud võimalused teada saada?
margus0000
Registreerunud 20.02.04
Auto: audi a3
postitati 11.09.05 19:54 Tsiteeri
Mõni targem võiks selle ingliskeelse jutu eesti keelde panna
westa
Registreerunud 26.06.03
Auto: Audi A6 Avant C4 2,5TDi,Audi A4 Avant 2,6 V6,Audi 100 C4 2,5TDi,Audi 5000 2,0d,Audi 80 B3 1,8
postitati 12.09.05 01:05 Tsiteeri
Algselt postitas: margus0000
Oleks ka tänulik :)
kama2
postitati 20.09.05 21:27 Tsiteeri
TõBras-e (Tõlkiv Brauser) abil siis on tõlge järgmine:
Muutuv Kraad Temperatuur Kuvar
Press ja hoidma recirculation nupp. Siis press temperatuur up ("+") nupp to lüliti vahel kraadi Celsiuse järgi & Fahrenheit on Kliima Juhtmine Temperatuur ja Instrument Paneel Väljas Temperatuur kuvar.
Juurdepääs On-Board Diagnostiline kood
Press ja hoidma recirculation nupp. Siis press käsiraamat voo reguleerimine up nool. Sa peaks nägema a 1c. Press temperatuur up ("+") või alla ("-") nupp to valima kood arv. Siis press recirculation nupp uuesti. Väärtus peaks kuvar. Press temperatuur up või alla nupp uuesti to kuvar teine kood.
MÄRGE: Õhk Voolama Mootor (V 71) ja Potentiometer (G 113) on mitte installeerima in USA/Kanada sõiduk. Eirama väärtushinnangud kuvar for need komponent.
Kood
Kuvar Väärtus
1
Süsteem talitlushäire - kuvar nagu Diagnostiline Häda Kood (DTC), nägema kaart allpool
2
Digitaalne väärtus of Sisemus Temperatuur Sensor, in Peaesineja (G 86)
3
Digitaalne väärtus of Sisemus Temperatuur Sensor, in Instrument Paneel (G 56)
4
Digitaalne väärtus of Värske õhk Sissevõtmine Juha Temperatuur Sensor (G 89)
5
Digitaalne väärtus of Väljas Õhk (Muutuv) Temperatuur Sensor (G 17), esi-
6
7
Digitaalne väärtus of Muutuv Temperatuur Sensor At Värske õhk Puhur (G 109)
8
Digitaalne väärtus of Temperatuur Regulaator Lapats Mootor Potentiometer (G 92)
9
Delta väärtus of Temperatuur Regulaator Lapats
10
Non-corrected täpsustama väärtus of Temperatuur Regulaator Lapats
11
Digitaalne väärtus of Kesk- Lapats Mootor Potentiometer (G 112)
12
Täpsustama väärtus of Kesk- Lapats
13
Digitaalne väärtus of Footwell/Sulataja Lapats Mootor Potentiometer (G 114)
14
Täpsustama väärtus of Footwell/Sulataja Lapats
15
Digitaalne väärtus of Õhk Voolama Lapats Mootor Potentiometer (G 113)
16
Täpsustama väärtus of Õhk Voolama Lapats
17
Sõiduk Kiirus (km/h)
18
Tegelik Õhk Puhur pinge (Volt)
19
Täpsustama Värske õhk Puhur pinge (Volt)
20
A/C Kompressor (A/C Haare) pinge (Volt)
21
Arv of madal pinge esinemine, non-transient
22
Tsükkel seisund of A/C Jahutussegu Kõrgrõhk Lüliti (F 118)
23
Rattasõit of A/C Jahutussegu Kõrgrõhk Lüliti (F 118)
24
Rattasõit of lülitid, absoluutne non-fluctuating
25
Analoog-/Digitaalne väärtus, Kick-Down Lüliti
26
Analoog-/Digitaalne väärtus, Mootor Jahutusvedelik Temperatuur (ELEKTRIŠOKK) Hoiatus Valgus
27
Kodeering väärtus
28
Mootor Kiirus (P/MIN)
29
A/C Kompressor kiirus in p/min (Võrdne Mootor Kiirus x 1.28)
30
Tarkvara versioon
31
Kuvar kontrollima (kõik segment of A/C Juhtmine Pea kuvar valgus up)
32
Potentiometer talitlushäire loendur, Temperatuur Regulaator Lapats
33
Potentiometer talitlushäire loendur, Kesk- Lapats
34
Potentiometer talitlushäire loendur, Footwell/Sulataja Lapats
35
Potentiometer talitlushäire loendur, Õhk Voolama Kaart
36
Tagasiside väärtus, külm end-stop, Temperatuur Regulaator Lapats Mootor Potentiometer (G 92)
37
Tagasiside väärtus, kuum end-stop, Temperatuur Regulaator Lapats Mootor Potentiometer (G 92), max. peatuma
38
Tagasiside väärtus, külm end-stop, Kesk- Lapats Mootor Potentiometer (G 112)
39
Tagasiside väärtus, kuum end-stop, Kesk- Lapats Mootor Potentiometer (G 112)
40
Tagasiside väärtus, külm end-stop, Footwell/Sulataja Lapats Mootor Potentiometer (G114)
41
Tagasiside väärtus, kuum end-stop, Footwell/Sulataja Lapats Mootor Potentiometer (G114)
42
Tagasiside väärtus, külm end-stop, Õhk Voolama Kaart Mootor Potentiometer (G 113)
43
Tagasiside väärtus, kuum end-stop, Õhk Voolama Kaart Mootor Potentiometer (G 113)
44
Sõiduk operatsioon tsükkel loendur
45
Kaalutletud sisemus temperatuur (seespidine tarkvara, in number)
46
Väljas (muutuv) temperatuur, filtreeritud, for eeskiri (seespidine tarkvara)
47
Väljas (muutuv) temperatuur, filtreerimata, (seespidine tarkvara, in deg C)
48
Väljas (muutuv) temperatuur, filtreerimata, (in number)
49
Talitlushäire loendur for spidomeeter (sõiduk kiirus) signaal
50
Staatus aeg (in protokoll)
51
Mootor Jahutusvedelik Temperatuur (ELEKTRIŠOKK) in deg C
52
Graafika kanal 1 - A/C kompressor switch-off tingimused on tuvastatud kõrval illustreeritud segment of the ?88.8? kuvar. Nägema kaart allpool.
53
Graafika kanal 2 - Kliima süsteem elektri- väljundid on tuvastatud kõrval illustreeritud segment of the ?88.8? kuvar. Nägema kaart allpool.
54
Juhtmine tunnus
55
Väljas (muutuv) temperatuur, in deg C või deg F sõltuma on seadmine on A/C juhtmine pea
56
Temperatuur in deg C, from Sisemus Temperatuur Sensor, in Peaesineja (G 86)
57
Temperatuur in deg C, from Sisemus Temperatuur Sensor, in Instrument Paneel (G 56)
58
Temperatuur in deg C, from Värske õhk Sissevõtmine Juha Temperatuur Sensor (G 89)
59
Temperatuur in deg C, from Väljas Õhk (Muutuv) Temperatuur Sensor (G 17), esi-
60
Temperatuur in deg C, from Muutuv Temperatuur Sensor At Värske õhk Puhur (G 109)
61
Tarkvara versioon (viimane)
Käsitsi ei viitsi küll tõlkida :D
TõBrase saab siit : TõBras
margus0000
Auto: audi a3
postitati 22.09.05 19:46 Tsiteeri
tanud:D
postitati 22.09.05 19:52 Tsiteeri
Kuigi olen varem tõbrast kasutanud, tundub see tõlge küll juba rubriiki "natuke naeru" kuuluvat. :D
TuRiK
Registreerunud 07.08.04
Auto: AUDI
postitati 25.11.06 23:28 Tsiteeri
mis see recirculation nupp on? mis seal peal on joonistatud?
postitati 26.11.06 10:05 Tsiteeri
Algselt postitas: TuRiK
Parempoolne alumine nupp. Õhu siseringlus eesti keeles.
Po18
Registreerunud 08.05.03
Auto: S4 avant 2.2 tq
postitati 26.11.06 10:35 Tsiteeri
Vähemalt viitsis mingi klubiline selle nüüd ära tõlkkida
Segways.webs.com
TuRiK
Auto: AUDI
postitati 26.11.06 18:30 Tsiteeri
t2nud! :D
Big
Registreerunud 26.11.03
Auto: Audi, Ford, Vaz
postitati 26.11.06 20:11 Tsiteeri
nüüd lõpetuseks võiks keegi siia teemasse kirja panna kuidas veakoode lugeda kliima kaudu, kui üldse saab.
sputnik
Registreerunud 30.08.06
postitati 09.12.06 01:59 Tsiteeri
Algselt postitas: trey
mul sama asi
keegi teab mis need ülejäänud on ?
kas neist 1-73 näitab ka mis pingega genekas laeb akut ?
ning kui on seal esimeses on veakoode rohkem kui üks kuidas ta siis neid näitab ?
tvarjund
Registreerunud 04.05.06
postitati 31.01.07 15:27 Tsiteeri
b6
aga kas 2002 aasta a4 kliimal saab kah vaadata? proovisin ei midagi....mul siuke variant kus off nuppu pole....2 siseõhu nuppu...yks A-ga teine ilma
Kari
Registreerunud 15.09.05
Auto: Audi 100 avant 92 a. 2,0 E. 85 kw . AAD, AXP
postitati 04.02.07 17:01 Tsiteeri
Mul mootori jahutusvedeliku temp. armatuuri kella järgi 91-93 kraadi ja kliima 51-koodi alt vaadatuna 86-88 kraadi. Küsimus kumba rohkem uskuda? Mõlemad näidud maanteel 90/ga sõites... PS termostaat on 87-me pealt avanev.
aivo_
Registreerunud 01.04.06
Auto: Audi A6 avant
postitati 04.02.07 22:34 Tsiteeri
Algselt postitas: Kari
Ei oska nüüd täpselt öelda kumba uskuda. Arvan, et aju töötab pigem selle anduri infi järgi mida kliima näitab. Kell võib vabalt valetada. Kiiruse puhul näitas odomeeter mul 230 km/h ja kliima 215km/h nii et kliima täpsem.
NB! Kliima järgi mingeid veakoode lugeda ei saa. See seal lihtsalt info.
Edit 01.05.07 : Saab veakoode lugeda neid mis puudutab kliimat. Üks link http://www.audiworld.com/tech/int5.shtml
Kõik mis on raha eest saadud on odavalt saadud...
A6S6
Registreerunud 31.03.07
Auto: A6 4.2
postitati 14.04.07 20:20 Tsiteeri
Kuidas saab sise.temp näidu Fararadite väärtuse muuta Celsiuse omaks?
aixx
Registreerunud 21.03.05
postitati 14.04.07 20:35 Tsiteeri
Algselt postitas: A6S6
Loe kolmanda postituse kolmandat rida
A6S6
Auto: A6 4.2
postitati 14.04.07 21:17 Tsiteeri
:) tänan!
Lugesin küll, kuid selle koha jätsin kahe silma vahele. ;)Proovisin econ ja auto nupu vajutust, kuid see oli vist VW climatronicu oma.
aivo_
Auto: Audi A6 avant
postitati 01.05.07 09:03 Tsiteeri
Selle kõige kohta üks hea link http://www.audiworld.com/tech/int5.shtml
Isegi veakoodide lugemise kohta kliima displeilt.
Vanja
Registreerunud 18.09.03
Auto: hetkel liikurita
postitati 27.06.07 18:36 Tsiteeri
Sellest kliima lisavõimalustest oli niikaua kasu kuni oli vanema kliimaga isend, nüüd on A6 1999 ja kliimas on funktsioonid erinevad, nii näiteks on kiirus C 17 ja mootori pöörded C 18 positsioonil. Mis puutub aga seda C 1, kus varem näitas olemasolevaid veakoode näitab nüüd 050, selle tähendust aga ei oska kusagilt leida, äkki oleks mingi abimaterjal ka uuemate kliimaseadmetele.
On olemas ka VAG-COM kuid see ei taha kliimasse ligi lasta, viskab ühenduse vigu ette ja katkestab ühenduse. Järsku on ka sellele mingisugune seletus?
[PHP: 60.3% - SQL: 39.7%]
