Lehekülgi: 1 2 3 4 |
Maku
Eero
Registreerunud 29.10.04
Auto: B2 2dq
postitati 24.01.08 08:38
sarnane lahendus ka pikes peakil sõitnud audi S1'l
Here one can see the air outlet for the air that has streamed through the engine compartement (on the hood). Also visible are the outlets for the
front wheel wells. Especially interesting is the air intake on the roof. It leads to the rear mounted water and oil coolers. Generally intake have to
be positioned in areas of high pressures, outlets should be where the pressure is rather low. While this is accomplished for the outlets here, fans
support the air stream for the big radiators in the back.
Joel
Registreerunud 01.10.02
postitati 24.01.08 09:29
R8 V12 TDi klaaskatusesse kombineeritud õhuvõtt on tegelikult Audi enda poolt juba täpselt samal kujul näidatud 1991 aasta Audi Avus Quattro Concepti
küljes:
Maku
postitati 24.01.08 10:03
Paratamatult tekib küsimus, kuidas nad selle intake'i puhtana suudavad hoida (lehed, lumi jne)? Ja kuidas nad vee eraldavad? Miski lihtne potsik,
kuhu koguneb vedelik ja voolab kuhugi minema ning õhk jookseb pealt poolt mööda?
postitati 24.01.08 20:52
tundub,et tuleb ka kolmas R8...
ehk siis kolmas.....ei olda veel kindel,kuid kes keelt möistab siis:
Although Audi hasn't made an official announcement yet, a prototype spotted on the Nurburgring points to the development of an even hotter version of
its R8 sportscar, possibly called the 2009 Audi R8-RS. Larger side air intakes were one tip off to the test car's nontraditional setup while revised
rocker panels were another. We're not sure if it will come badged as R8-RS, or simply RS8, but it appears as though there's a good possibility this
range topping two-door will get a version of the 5.2-liter V10 currently found in the S6 and S8 sedans. Expect around 500 horsepower from the V10
which will separate it from its sedan siblings without infringing on Lamborghini Gallardo territory. Expect to see this version of Audi's super coupe
arrive sometime in 2008.
mkendra
Registreerunud 27.08.06
Auto: mis iganes kätte juhtub
postitati 07.02.08 21:10
kas keegi teab,kas uus r8 reklaami lugu on ainult selleks reklaamiks tehtud või on mingi täispikk lugu
MK
Audi Eesti
Registreerunud 30.08.07
Maku
MorroW
Registreerunud 18.09.06
Auto: 100 Avant 2.6 q
ICE
klubiliige ac aasta auto 2006 võitja
Registreerunud 27.09.02
postitati 29.08.08 11:27
Täitsa huvitav isend. Ma ei saa küll aru, et kelle jaoks see ikkagi tehtud on. See, et ta tagaveoliseks tehti ning selle tarbeks täiesti uus (?) kast
toodeti, tähendab et ringraja vallutusplaan võiks tõsine olla. Aga et mingi tiib, istmed ja puur seal sees? Üldjuhul käib võidusõidus asi ikka nii, et
klient kasutab niiöelda ainult toorikut ning kõik muu tehakse custom tiimi enda poolt vastavalt vajadustele. Või lisati need nimetatud jubinad, et
talle mingi kommertslik esialgne välimus anda, mida ajakirjanikud pildistada saaksid...
Raisk ta on liiga seksikas ringraja jaoks
raimsb6
Registreerunud 30.07.05
postitati 29.08.08 16:03
Kuna GT3-s tootjad ise ei osale, siis on see mõeldud ikkagi tiimidele, kes seda ostavad ja sarjas kasutama hakkavad (loodetavasti). Ma ei ole väga
kursis, aga kas mitte GT3-s ei ole piirangute tõttu väga palju võimalik toodetud autot modifitseerida?
Kuna see saadaval alles september 2009.a. siis rajal saab näha alles ülejärgmisel hooajal kõige varem. Igatahes väga kena
tarmo
Registreerunud 05.01.03
postitati 17.09.08 14:11
GT3-s on 4wd keelatud
postitati 22.09.08 13:06
Link: MTM R8R
MTM on nüüd ka käpa R8 külge saanud. V8 mootorile lisati supercharger, mis tõstab võimsuse 560HP-ni ehk võrdseks vanema õe Lamborghini Gallardo-ga.
Kood: | MTM R8R Technical Data:
engine V8 compressor, twin srew supercharger belt driven
capacity in ccm 4163 ccm
drilling x stroke in mm 84,5 x 92,8 mm
densification 12,5 : 1
gearbox construction type 6-speed manual gearbox
power (max.) 560 PS (412 kW) bei 7.750 U/min
supercharging pressure (max.) 0,55 bar bei 7.750 U/min
torque (max.) 580 Nm bei 5.500 U/min
Vmax limited (unlimited) 301 km/h (315 km/h)
acceleration 0 -100/200 km/h: 3,9 sec./12,5sec
drive permanent all-wheel drive Quattro
brakes VA 380 x 34 punched, ventilated
HA 356 x 32 perforated, ventilated
rims VA mtm bimoto Forged 9 x 20" ET 42
HA mtm bimoto Forged 11 x 20 ET 50
tyres VA Michelin Sport Cup 245/30-20"
HA Michelin Sport Cup 315/25-20"
kaharm
Registreerunud 11.07.07
Auto: S2 3B & S2 ABH & Coupe V6 & 1x V8 PT & 1x V8 ABH & S4 AAN & 90Q & Roheline NIVA 1.7 & Punane..
postitati 04.10.08 11:18
kui pole raha r8 osta siis saab prismast sellise vähem kui saja krooniga.
Aleksandr
Registreerunud 15.03.05
Auto: Honda
Taavi
Registreerunud 21.11.04
Auto: UrS4
postitati 06.11.08 20:51
Jäi lihtsalt silma:
Audi R8, 5200ccm, 386kW, Engine code BUJ.
12.301@181km/h
TT
Registreerunud 08.06.04
postitati 07.11.08 07:12
V10 R8-l on reaalsus ja tulekul aastal 2009.
MorroW
kikunaator
Registreerunud 07.10.07
Auto: Audi 80 B4 2.6E
postitati 01.05.09 12:02
Korras unistuste auto olemas.
kikunaator
postitati 01.05.09 12:03
Kes oskab öelda millal Audi R10 seeriasse jõuab!?
postitati 01.05.09 12:18
Tsitaat: | Algselt postitas: kikunaator
kes oskab öelda millal Audi R10 seeriasse jõuab!? | Kas sa mõtled R8 V10 mudelit?
kikunaator
postitati 01.05.09 12:47
Ah nii on asi hoopis. Olen ise midagi segi ajanud sorry.
Muidu jah R8 V10...
Maku
postitati 01.05.09 13:27
Muideks R8 V10 on ka Revali salongis. Kohe mitte ei saanud külma kõhuga mööda kõndida.
