 Lehekülgi:  1  2  3
Pealkiri: Audi TTRS (Vastuseid: 53 | Vaatamisi: 43319)
Silwer
Registreerunud 11.12.02
postitati 19.01.08 15:52 Tsiteeri
Audi TTRS
TTRS tuleb siis väidetavalt 5 silindrilise 2,5 liitrise mootoriga. Kasutatakse kombinatsiooni kompressorist ja turbost ning jõudu lubatakse 343hj.
http://www.autocar.co.uk/contentImages//Car/Audi/TT/51277105520.jpg
"It’ll be both supercharged and turbocharged, becoming the second motor in the VW Group’s line up to wear the TSI ‘twincharger’ badge. And Audi sources say it sounds every bit the modern successor to the original Quattro’s warbling five-pot."
Ehk siis tundub et vana hea 5 silindriline saab ühe väärika järglase... :)
BMW 325i E30 2,8 stroker & BMW 328iT E36 & Seat Altea XL 2,0 TDI+DSG
postitati 24.01.08 20:41 Tsiteeri
TTRS
http://www.edmunds.com/apps/vdpcontainers/do/MediaNav/year=2008/make=Audi/model=TT-S/firstNav=Gallery/photoId=20105735
lisaks oli veel tiba sellist juttu:
Following about a year after the release of the upgraded 2008 Audi TT-S, the 2009 Audi TT-RS will be the top of the line model in the lineup. Currently undergoing development at Audi's Ingolstadt headquarters in Southern Germany, the TT-RS will be Audi's answer to rival go-fast coupes such as the BMW Z4 M coupe and Porsche Cayman S. Rather than the 3.6-liter V6 engine as widely rumored, Inside Line can confirm the range-topping TT is set to become the first Audi model to receive a new turbocharged version of parent company Volkswagen's long running 2.5-liter five-cylinder as found in North American versions of the Jetta. Updated to accept the same cylinder head configuration as the 5.2-liter V10 used in the S8 along with the latest direct-injection technology from German specialist Bosch, the new Audi engine is said to deliver in the region of 365 hp. That's some 22 hp more than the Z4 M Coupe. As with the TT-S, the TT-RS will place its power to the ground via either a standard six-speed manual or an optional seven-speed version of Audi's S-Tronic double-clutch gearbox, with a Haldex-style four-wheel-drive system, which uses a multi-plate clutch instead of Audi's more traditional Torsen-based arrangement, apportioning drive to all four wheels.
Maku
postitati 03.09.08 21:34 Tsiteeri
TTRS
Selline video. Spekuleeritakse erinevaid asju, kes arvab, et tegemist R5T mootoriga, kes pakub V lahendust.
Konrad
Registreerunud 27.09.06
Auto: TT RS Roadster / Abarth 124 Spider
postitati 22.02.09 21:29 Tsiteeri
Audi TT RS
Fourtitude`is selline info TT RS-i kohta:
Link
Minu jaoks oli kõige huvitavam osa uue R5 soundtrack:
Kõik uus on taasavastatud vana :D
Jääme siis Genfist uut infot ootama.
MartinCS
Registreerunud 28.03.06
postitati 22.02.09 21:53 Tsiteeri
At the heart of the TT RS is a turbocharged 2.5-liter turbocharged FSI 5-cylinder engine – a return for Audi to the iconic force-fed 5-pot configuration. Early official information from Audi confirms power at “above 300 hp”, though Fourtitude has heard at least 350 hp from senior Audi executives directly involved in the car’s development. That’s enough to move the TT RS from 0-62 mph under 5 seconds… “nowhere near 5 seconds,” according to a quick blurb in the official teaser info from Audi. A supposed leaked German dealer document published back in October claimed 0-62 in 4.5 seconds and a consumption of nearly nearly 24 MPG (“under 10 liters”).
That same document listed a few more important points. For starters, official power figures should be 340 hp and 332 lb-ft (450 NM).
Hehee, tea palju vanast 20vt'st seal sarnast tuleb? :D
ICE
ac aasta auto 2006 võitja
Registreerunud 27.09.02
postitati 22.02.09 23:04 Tsiteeri
Tea, kas meie lastele kujuneb sellest mootorist kunagi samasugune lelu, nagu seda praegu on 20vt? :D
TT
Registreerunud 08.06.04
postitati 04.03.09 14:20 Tsiteeri
Väga muljetavaldav graafik on antud mootoril:
Nm kõver hakkab 1000 rpm-i juures 130 Nm-ga, juba 1600 rpm-il on saadaval maksimaalne 450 Nm ning sirge joon hakkab kukkuma alles 5300 rpm-i juures.
Jõukõver algab 1000 rpm-i juures 30 kW-st, liigub 2000 rpm-i juures 100 kW-ni ning seejärel üles 5400 rpm-ini, mil saavutatakse masimaalsed 250 kW.
Auto tühimass on kupeekerega masina puhul 1450 kg ning roadsterkere puhul 1510 kg.
Autol kasutatakse kahjuks veel vana, Volkari 6-käigulist DSG kasti (ilmselt suhteliselt tubli pöödremomendi tõttu).
Auto kütusekulu on tehase andmetel: linn - 13,1 l/100 km; maantee 6,9 l/100 km ja kombineeritult 9,2 l/100 km.
Eraldi väärivad aga mainimist TT RS-i kiirendusnumbrid:
0-100 km/h = 4,6 sek; 0-200 km/h = 11,3 sek.
Toon siia võrdluseks Audi RS6 Avant 5,0T FSI:
0-100 km/h = 4,6 sek; 0-200 km/h = 14,9 sek.
Audi R8 4,2 FSI:
0-100 km/h = 4,6 sek; 0-200 km/h = 12,0 sek.
Tonx
Registreerunud 08.03.06
Auto: G31 540; Tucson AWD
postitati 04.03.09 14:39 Tsiteeri
Mõnda aega tagasi mõtlesin, et miks pole Audil ühtegi uut 5potist püssi - aga näedsa siis!:cool:
Andmed on ikka väga head(Y)
EDIT:
Väike video Genfi näituselt: LINK
Köis kaasas. Helista:D
Jürarrak
ac aasta auto 2008 võitja
Registreerunud 15.04.03
Auto: Some quattro GmbH Cars
postitati 04.03.09 21:47 Tsiteeri
Audi R8 4,2 FSI:
Kas ta nüüd nii välek ikka on? @ 0-200km/h=11,3sek :o
Sellise võimsuse ja kaalu suhte järgi on see üsna ebareaalne.
Võrdluseks üks teine sait:
http://www.fastestlaps.com/car_Audi_TT-RS_Coupe.html
Parem must minevik kui lilla tulevik
TT
postitati 05.03.09 10:13 Tsiteeri
Minu jutu aluseks ei ole saitidelt pärit informatsioon vaid paberkandjal olev informatsioon, mis pärineb Audi AG-lt.
Väidetavalt on Saksas mõõdetud viienda rattaga 0-100 km/h 4,5 sekundit.
0-200 km/h sellist aega võib täiesti uskuda sest TT RS ei ole kiirusel, mil saabub pidamine, enam nelikveoline.
Ehk siis kaob ära 35%-line transmisioonikadu, mis kahjuks RS6 puhul saatuslikuks saabki, oma pideva nelikveo tõttu.
Joel
Registreerunud 01.10.02
postitati 05.03.09 11:22 Tsiteeri
See TTRS on nende andmete kohaselt ikka täiesti müstiliselt kiire aparaat. Võrdluseks mõned autod, mis TTRS'ile 0-200km/h ajalt alla jääksid:
Chevrolet Corvette Z06 513hp/638nm - 11,9 sek
Ferrari F430 489hp/465nm - 12,2 sek
Lamborghini Gallardo LP560-4 560hp/650nm - 11,8 sek
Porsche 997 Turbo 480hp/620nm - 12,1 sek
Pagani Zonda F 602hp/760nm - 11,4 sek
Ei võta vastutust lingitud saidil toodud andmete õigsuse osas. Lihtsalt võrdluseks välja toodud...
TT
postitati 05.03.09 12:13 Tsiteeri
Sain tehasest vastuse oma päringule, millest selgub, et "targas raamatus" on trükiviga.
Nimelt 11,3 sekundit ei kiirenda auto 0-200 km/h vaid 11,3 sekundit kiirendab auto 100 - 200 km/h.
Järelikult kiirendab TT RS 0-200 km/h 15,9 sekundiga.
Ja eks reaalsed numbrid selguvad alles auto tulekuga.;)
Eero
Registreerunud 29.10.04
Auto: B2 2dq
postitati 05.03.09 12:33 Tsiteeri
Algselt postitas: TT
Küsiks, et kas r8 ja rs6 toodud võrdlustes on sama viga sees?
TT
postitati 05.03.09 14:12 Tsiteeri
Hea küsimus:D
Uurime järele.
Maku
postitati 04.04.09 11:29 Tsiteeri
Audi TT-RS - real life photos
forsin
Registreerunud 01.07.04
postitati 24.06.09 13:12 Tsiteeri
Lugesin ka rootslaste juttu , neil sammuti hea meel et turbo rida viis on tagasi.
http://album.ee/node/20208657/16958024
uus moto->
http://album.ee/node/20208655/16958024
vana moto fännamine
http://album.ee/node/20208653/16958024
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 25.06.09 11:30 Tsiteeri
Ilmselt jälle kasutatud pisemat mõõtu vilet varase ärkamise huvides - sellele viitab ka see 5400 rpm juures tippvõimsuse saavutamine...
Matrix
Registreerunud 13.02.07
Auto: Coupe
postitati 25.06.09 13:11 Tsiteeri
Kui see lõpuks välja tuleb, siis tahaks teada, mis pakette MTM sellele pakkuma hakkab. Ehk on siis näha veidi mootori tegelikku potensiaali.
Samzik
Registreerunud 12.09.04
Auto: Passat 1.9/96kw 4WD 2004, audi 90 2.1/134kw q 87A
postitati 25.06.09 13:12 Tsiteeri
Samas pane tähele, et seal spekuleeritakse kompressorit. Seega ei saa väga väike vile olla, pigem liiga väike intercooler, nagu tehasel kombeks :)
Pakkuda uus Haldex õlipumba elektrimootor. E parandan mittetöötava mootori+uued tihendid. Mbl: 55 55 88 55.
wirx
Registreerunud 21.05.07
Auto: Audi TT jpt
postitati 07.07.09 13:41 Tsiteeri
viimases Car ajakirjas, mis statis müügis on sees review ka
http://www.carmagazine.co.uk/Drives/Search-Results/First-drives/Audi-TT-RS-Coupe-2009-CAR-review/
Mulle meeldib, et kaal on suudetud mõnusalt väikseks jätta ning chipi ja mõne väiksema tuuningu võttega võiks loota 400hj kanti, ehk siis mybe isegi alla 4 seki 0-100 :)
http://www.laptopid.ee Audi omanikule vähemalt -5% hinnast
genekas
postitati 11.07.09 20:15 Tsiteeri
Praeguse aja trendide juures on 1450 kg tõesti kergeks peetav - kuigi isegi 15 aasta tagune RS2 kaalub natukese rohkem.
Samzik
postitati 11.07.09 20:20 Tsiteeri
Ja arvestades mida ta kõikke sisaldab siis on ta üsna kerge. Samas lisaks alumiiniumile kasutavad nad kere konstruktsioonide juures Kõrg karastatud terast mis teeb autod kered pea poole kergemaks.
Algselt postitas: generaator M
postitati 21.07.09 05:37 Tsiteeri
Hommikul lamppi leidsin. >>>juutuubist
EDIT1: üks veel, saksakeelne
Hobiautode hoiustamine | Põrandaplaatide ja LED valgustite müük HobiHoid.ee! Rolevents digiturundus
twistY
Registreerunud 06.05.09
postitati 21.07.09 13:19 Tsiteeri
Algselt postitas: Kivitare
Maku on juba kolmandas postituses "lamppi" esimese video lingi lisanud.
Maku
postitati 10.10.09 10:14 Tsiteeri
460 hj Avus Audi TT-RS on kiirem kui R8 V10
Uueks ur-qattroks pürgijate nimistu on saanud värske esikoha. Tuuningufirma Avus punnitas Audi TT-RSi viiesilindrilisest turbomootorist välja pea pooltuhat hobujõudu, mis on omas kitsas klassis absoluutne tippmark.
Tehaseseades pakub Audi viiesilindriline 340 hj, mis katapulteerib auto kiiruseni 96 km/h 4,6 sekundiga. Mida siis veel tahta? Avus annab 460 hj ja 640 Nm väänet. Selles on süüdi vabamalt hingav väljalase, modifitseeritud juhtaju ning võimsam turbolaadija.
Nüüd saabub 96 km/h pelga 3,8 sekundiga ning tippkiirus ulatub märgini 320 km/h.
Sellised dünaamilised näitajad on omased pigem Audi enda superautole R8 V10 5,2 FSI, märgib Autoblog tabavalt.
Mattmusta masina alla kruvitud on 20-tollised mustad Sportec Mono veljed, mida katavad 255/30-20 Hankook S1 Evo rehvid. Vedrustus on loomulikult jäigem ning reguleeritav ning Avus TT-RS'i juhitavus tavamudelist veelgi parem. Avuse teenus maksab kenasti juba ilma hobujõude lisamata. 9.700.- euro eest saab veljed ja rehvid, vinüülvärvkate on 2000.- jne. Mootori järeleaitamise maksumuses lepitakse kliendiga ise kokku.
 Lehekülgi:  1  2  3
[PHP: 60.7% - SQL: 39.3%]
