Pealkiri: RS4 4.2 edasiarendus (Vastuseid: 11 | Vaatamisi: 10124)
Maku
postitati 19.08.09 06:22 Tsiteeri
We dyno'd the car first with the same stock map but this time with the MRC modified intake manifold. (Red line)
We then remapped the ECU to further increase gains. (Blue line)
Baseline run done 4 days before (blue line)
After proving that cleaning and modifying the inlet track made a significant increase to the power of the engine it was now time to work on the exhaust system.
Some free flow downpipes were fitted and the cars ECU was remapped again to take full advantage of the exhaust airflow.
We were very pleased with the end result with the car making 430bhp and 340ft-lbs and gains of up to 50bhp and 50ftlbs in the rev range.
RS4 B7 Development
Pildid soovitan uues aknas lahti võtta.
Maku
postitati 02.04.10 10:24 Tsiteeri
Selline küss, et kas keegi on kohanud stroker kit-i Audi 4.2-le? Netist jäi silma selline lause: a stroker kit for the 4.2 V8 would bring it to about 4.7 liters..
http://pictureposter.audiworld.com/showthread.php?p=18315769
Maku
postitati 16.12.10 23:53 Tsiteeri
Evolutions of a RS4 B7
MartinCS
Registreerunud 28.03.06
postitati 17.12.10 00:58 Tsiteeri
Ei ole küll tehniline info, aga võibolla on kõige parem edasiarendus kompressor. Youtubest kui vaadata mis pöörete juures jõud tuleb, tekib ikka kerge kadedus. Sinna juures siis veepritse. Väänet on vist niikuinii sellise komplekti juures juba piitatud kasti ja veermiku pärast..?
edit: 550nm on ikka vähevõitu sellise mootori ja kopressori jaoks..
jõuvanker
Registreerunud 21.03.03
postitati 17.12.10 08:24 Tsiteeri
Mis ikka pikalt otsida?!
end3l
Registreerunud 27.06.07
postitati 17.12.10 11:09 Tsiteeri
Algselt postitas: Maku
Loe ka edasi:
Hmmmm........if they made one, lol. An extra 40hp for about $4000.
Ehk siis: Kui seda vaid tehtaks, lol. Lisa 40 hp'd umbes 40000eek eest.
Konrad
Registreerunud 27.09.06
Auto: TT RS Roadster / Abarth 124 Spider
postitati 17.12.10 21:03 Tsiteeri
Brittide foorumis selline komplekt, tsiteerin:
"Pes supercharged by Mrc (M112 supercharger) snow performance stg3 water meth inj !kw v3 coil-overs hr arb's!jhm trio short shift kit sachs clutch and flywheel.brembo big brake kit Milltek no cat dp's and back with satin black tips non res."
Tulemus: 564 ps and 684 nms
Linky
turbo
Registreerunud 03.10.03
Auto: S6
postitati 17.12.10 21:34 Tsiteeri
Äkki oleks kohe targem orikas osta :
MTM
Konrad
postitati 17.12.10 21:47 Tsiteeri
Kui me juba B5 RS4-ja B7 RS4-ja orikaks loeme, siis oleks veel "targem" päris RS osta...
Äkki sa mõtlesid seda: MTM RS4 Clubsport ?
turbo
Auto: S6
postitati 17.12.10 21:59 Tsiteeri
Oleneb, mida keegi originaaliks peab, porgelt mahatõmmatud juppidega ja müügijaoks upitatud audit või midagi muud....
Maku
postitati 18.12.10 07:50 Tsiteeri
Proovime siin teemas jääda 4.2 piiridesse.
Maku
postitati 13.02.11 00:02 Tsiteeri
386->461ps
386ps @ originaal
423ps @ kattideta Milltek väljalase, nelja tolline õhuvõtt, tarkvara optimeerimine
461ps @ puhastatud ja porditud sisselaske kolle ja sealt klapid minema visatud + eelnev
LINK
[PHP: 43.6% - SQL: 56.4%]
